Results 1 to 14 of 14
Thread: How stiff should the ride be?
    Jan 2011
    2000, Foxfire, 0519
    Hard to explain without someone being in the car and feeling it. How stiff are other's VX stock? Mine bounces on hard bumps, and it's hard to keep anything anywhere when it bounces. Don't get me wrong, I know this isn't going to ride like a normal SUV, I just want to see if it's normal.
    99 Silver 515
    Stiff ride
    Mine is very stiff also. Seems like the radar detector will come flying off the window every time I hit a bump, and the power connector in the cig lighter will disconnect causing it to reset. I have the original shocks, not lifted in anyway and stock sized tires ('99 16in). I believed it was normal, needed to get the sports car handling that I truly enjoy.
    Tons of posts about this....use search function.... "OEM shocks", "bump stops", and such.
    VERY stiff OEM ride....shocks are extremely rough.
    Many have replaced them with Rancho 9000s with the 9 way adjustable settings.
    Some of us (myself, vt_mav) have recently cut our rear bump stops in half and have seen a TREMENDOUS improvement in that real jarring/slamming effect on the rear of the vehicle.
    Jan 2011
    2000, Foxfire, 0519
    Ah, ok. I'll do some better searching, thanks.
    To save you the headache, start here: Bump Stops
    Lots of good posts with pics of what needs to be done. I would HIGHLY recommend you start by cutting your bump stops, THEN proceed to shocks only if the ride quality is still too harsh for your tastes. Cutting the bump stops can be done with any common saw blade and for only the cost of your time. Shocks can run from $200 on up depending on the brand, so IMHO start with the cheap fix and work your way up.
    Jan 2011
    2000, Foxfire, 0519
    awesome, that bump stop mod looks super easy. hell, I may try it tonight.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    If you plan on lifting your vehicle at all(or in the future), then I would wait to cut the stops. When you lift, it pushes the bumpstops away from the axle and in several cases(myself included) you actually need extensions in order for your bumpstops to work at all anymore. One of the reasons bumpstops are there is to prevent your expensive shocks from bottoming out and being destroyed. Cut with caution. It may also affect future resale......
    I got an extra set from a junkyard just in case I didn't like the outcome....but then was so happy with it I knew I'd never go back, so I shipped the extra set to Mav.....he used them, and his originals are now sitting as his spares. So that's one way around that issue.....get a spare set.
    May 2012
    2001 Iron Man,Vehicross,0814
    The ride drove me crazy for a long time. What I have done is taken the harshness out of the front end by removing the sway bar. Huge improvement and no noticeable difference in cornering. Easily done without even removing the wheels. Before I did my lift, I cut the rear bump stops to half height, then after the 3 inch lift I removed them entirely. Still not the best riding car in the universe but better.
    May 2012
    I've done just that. Still the Rancho 9000's leave something to be desired when it comes to rebound damping. Anyone else have that complaint?? Or is there a better after-market shock available.
    Feb 2004
    '01 Ebony #0830
    Another member had really bad jarring on his stock VX and he just replaced his tires (to Nitto Terra Grapplers) and it fixed the issue! I personally rode in his VX before the swap. It was BAD. I didn't think that tires could fix this, but lo and behold........
    Nova, chime in if you can.
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    May 2012
    I don't think thats it. I just put on Toyo Cross Country 33x11.5, no diff.
    I found the overall ride much, much better with the Toyo's. The arse end pogo's out of a dip, thats shocks. Or possible shock settings with the Rancho 9000's. Mine are set at 8.
    Jul 2009
    Do you know if you're running stock springs and/or torsion bars?
    Vixer Fixer
    May 2012
    Running 3" lift. I think that maybe the Rancho 9000 shock is topping out with the 3" lift I have on my VX.
    From what I can gather the Rancho 9000 is 4.125" stroke for the front shock and 6.125 stroke for the rear shock. The Old Man Emu is 5.51" stroke for the front shock and 7.48" stroke for the rear shock.
    My complaint is related to the rear. So going to OME on the rear would gain an additional 1.36'' of stroke. Body travel is somewhat vertical but the shock is not, because it is inclined. So the gain in up travel would be less than 1.36" verically. Not sure if there would be much of a ride improvement at all.
  1. The New Ride!
    Last Post: 03/17/2009, 12:54 PM
  2. Snowboards.....what do you ride if you ride?
    By morgan-tec in forum VX Talk...
    Last Post: 12/30/2005, 11:17 PM
  3. New Ride!(with pic.)
    Last Post: 07/11/2005, 07:18 PM
  4. Which Ride ?
    Last Post: 03/15/2005, 09:12 PM
