Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 58
Thread: CV Boot Replacement...or how to save $1600!!!!
    Today I replaced my torn CV boot at home. Isuzu will tell you the CV's are NOT a servicable part and that the entire shaft needs to be replaced at a cost of $850 per side. Since I had everything apart I changed both the inner and outer boot. Parts cost me $33 for both the inner and outer boot (x2 if doing both sides) and another $2.99 for a can of break cleaned. $36 vs. $850!
    All you need is a willingness to get dirty and greasy and about 2 hours of your time.
    So here is the proceedure...(I must give mad props to James (Spazz) and Dan Houlster who's 4x4Wire tech article were of much help)
    Here is the culprit...
    The torn boot
    Very few tools are needed to do the job
    1 jack, jack stands, a deep 17mm socket, ratchet (a long one helps for leverage needed), snap ring pliers, a screw driver, rags and a can of brake cleaner. A band tool is helpful also...I didn't use one and it was a pain but I got it done.
    Cont.
    Jack up the front of the VX and place it on jack stands.
    Remove wheel/tire.
    Place jack under lower control arm and lift to relieve pressure on the lower ball joint.
    Remove the 4 17mm bolts on the bottom of the lower control arm that hold the ball joint bracket.
    Cont.
    (yes, that is duct tape as a VERY temperary fix till I got a chance to do the boot change! )
    Next reposition the ball joint bracket to the top of the lower control arm.
    Remove the bands from the INNER CV BOOT.
    Move boot off of CV Joint.
    Cont.
    Clean as much grease out as you can. Rags and brake cleaner work great.
    Next locate the wire ring just inside the inner lip and slide a screw driver under it. Pop the ring out. Thiis is the retainer ring that holds your CV joint and axle shaft in!
    This is the ring once remoced.
    Cont.
    Next you pull the CV joint out by pulling the brake assembly outward.
    This is the result.
    Be prepared for the balls to fall out.
    This is what the CV joint will look like...yeah its greasy!
    Use the brake cleaner and rags to clean it up.
    Use a screw driver to remove the 6 balls.
    Cont.
    There is a snap ring on the end of the shaft.
    Remove the ring with snap ring pliers.
    The snap ring once removed.
    Next remove the the inner part of the CV joint from the splined shaft.
    I needed to use a small gear puller on mine since it was pretty tight.
    Once removed notice the recessed inner part on one end. That side goes on first when reinstalling it or it will not fit on all the way.
    You can see it here...
    Cont.
    Now the outer crown will also come off. Notice which way it comes off for reinstalling later. Here is all the CV joint parts removed...
    Remove the inner boot by removing the small band and sliding the boot off the shaft.
    Now remove the large and small band from the outer boot. Then slide the outer boot off the shaft.
    Clean the outer CV joint using the brake cleaner and rags. You can also use high pressure air to blow out the CV joint. The thing is you need to get out any dirt that may have gotten into the CV joint through the tear in the boot.
    Cont.
    Now you are ready to start putting it back together.
    Fill the outer CV joint with grease supplied in the boot kit. Get it as deep into the joint as possible. Then apply the new outer boot per the instructions in the boot kit (the kit contains the boot, boot sraps and grease).
    Slide the outer (large end) on and apply the strap. The strap tool really would have helped here but I managed by using a scwer driver, pliers and cutters. You then "burp" any extra air out of the boot by sliding a screw driver under the small end and squeezing the boot. Remove the screw driver and allow the boot to go back into shape. Apply the small end strap. The straps line up on the grooves on the large end and on the groove on the shaft on the small end.
    Next slide the new inner boot on (small end first).
    Next put the outter CV joint back together the opposite of taking it apart.
    Outer cage, center piece onto splined shaft, snap ring, and then the balls.
    Apply grease to the parts and balls. This will help keep it all together.
    Now carefully manipulate it back into the space it came out of. You will have to move the assembly around until it all lines up and then it will just drop right into place.
    Cont.
    Fill with remainder of grease.
    Now slide the large end of the boot into place and secure it with the supplied strap. Burp the air and slide the small end into place on the shaft. Apply the small strap.
    Now reposition the ball joint bracket back under the lower control arm.
    Use the jack to lift the control arm until the holes line up for the bolts.
    Insert the bolts and tighten up the nuts. Torque specs are found in your manual.
    Put your wheel back on.
    Repeat for other side if needed.
    Lift VX with jack.
    Remove jack stands.
    Lower VX.
    You ready to roll with a lot of saved cash in your pocket for your trip to Moab next May!
    Great pics & write up Billy, I've been watching it materialize & know how much time you've spent posting pics etc...you're a far more patient, persistent & detail oriented man than I. I salute you!
    Outstanding!
    Clear pics, great narrative, HUGE $$$ savings, what else can be said? This is what makes this forum great. To paraphrase from an old (and hilarious) post about what's happening on other car forums...
    Bentley Forums
    - - - I used the ash tray today. How do I replace it?
    Worth another look...
    http://www.vehicross.info/forums/sho...hlight=bentley
    Velvis
    thankyouthankyouverymuch
    Sep 2005
    1999 Astral Silver VX #0351
    Kudos for going the extra mile and putting together a superb guide!!!
    Feb 2003
    2001, Black, VX, 0781
    You might want to host the pictures here in case AOL ever decides to "realign their internet business" and stop providing free hosting.
    Another fine write up Mr. Oliver!
    Thanks from everyone here, we appreciate how much time and consideration it takes to step away from the tools and take a few pictures. This easily doubles the time of the job. Thanks again,
    Nov 2002
    Excellent write up and photos! This is what this community is all about. THANK YOU!
    PS: If you'd like to permanently host your how-to somewhere, I'd be more than happy to copy it to my VX site.
  1. CV Boot Replacement Plan - Correct me where I am wrong
    Last Post: 05/06/2014, 01:39 PM
  2. CV Boot Replacement - Problems removing control arm bolts
    By RedBlur in forum VX Troubleshooting...
    Last Post: 01/06/2014, 05:38 PM
  3. God save me.........PLEASE!
    Last Post: 06/27/2009, 10:02 PM
  4. How can i save some gas?
    By billybob in forum VX Troubleshooting...
    Last Post: 10/19/2007, 02:36 PM
  5. Save gas your way, I'll do it my way
    Last Post: 08/18/2007, 07:54 AM
