Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: Independent4x Steering stabilizer - anyone install this yet?
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Seems like a problem that some of us have. I'm interested in knowing if anyone has tried one, and if so, do you have any feedback?
    http://www.independent4x.com/Isuzu-S...zer_p_299.html
    "This steering stabilizer is specifically engineered to improve handling characteristics and reduce wheel vibration, which leads to suspension component fatigue and failure.
    Available in a single shock configuration for Isuzu trucks, this stabilizing system is designed to help reduce bump steer problems caused by over sized tires and rough roads. The twin tube hydraulic performance shock reduces aeration and fluid foaming with 10 stage velocity sensitive valving. An internal bump stop eliminates damage caused by over extension. The shock has a 1 3/8" nylon banded piston and a 5/8" chrome hardened piston rod.
    Fits all Isuzu years with a steering box....does not work on Rack and Pinion steering trucks ('98+ Rodeo, Amigo, Rodeo Sport, Axiom)
    APPLICATIONS:
    85-95 Pickup & Amigo
    89-97 Rodeo & Passport
    84-2002 Trooper, VX
    TIA
    Aug 2008
    Nope, we are all waiting for YOU to be the first!!! Please keep us posted after you install it.
    Aug 2011
    2000, firefox, base,
    Its really just meant for solid front axle
    whitebread
    Quote Originally Posted by whitebreadx View Post
    Mebbe but may help with bump steer ... & can't hurt.
    Mar 2012
    sold
    personally i think the vx handles great but if it doesnt help you can always bake a pie with the rolling pin
    1999, Ebony Black, VX, 1614
    Its pretty inexpensive to try. I will be anxious to hear your results.
    Oct 2003
    1995 Isuzu Trooper LS
    Can't imagine why you would need it, I've been driving the same steering/suspension as you guys, with 35" tires, for years, never had an issue with bump steer. Maybe the longer wheelbase helps.
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    My bump steering is pretty atrocious, but I also need to replace the shocks and ball joints.
    I'll give all of this a whack first to see if it resolves the issue, and if not, this will be my next step.
    If your bj's are bad that will sefinately cause it. While in there also check wheel bearings and upper/lower control arm bushings.
    Nov 2012
    If your bj's are bad that will definitely cause it.
    Never encountered such a thing as a bad BJ. Some are just better than others. If your BJ's are bad just keep practicing.
    There's no 'I' in denial.
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Never encountered such a thing as a bad BJ. Some are just better than others. Triathlete, if your BJ's are bad just keep practicing.
    Fixed that for you, as I never mentioned anything but ball joints
    www.thefundamentalelements.com
    On washboard dirt roads I have to drive so slow to keep from bouncing all over the place.
    How does this help and where would it be mounted on the VX?
    Nov 2012
    When you say bouncing all over are you talk about up and down? Or kind of getting jerked side to side? If it's side to side a stabilizer may help but I think what others are getting at is it may be putting a band-aid on to cover up a problem elsewhere. Since it's reasonably cheap and easy to install that's not necessarily a bad thing.
    There was a picture on the planet that kind of gives you an idea of where it mounts.
    Bouncing around on dirt roads is more a result of the short wheelbase.
    That stabalizer is a nice rock anchor.
    Nov 2012
    That stabilizer is a nice rock anchor.
    Yeah, I don't think it would survive long under my VX, as others can attest I'm not the most gentle off-roader.
    I am seriously thinking about going with the HD torsion bars though to decrease bounce and dive.
  1. steering stabilizer
    By whitebreadx in forum VX Talk...
    Last Post: 10/25/2013, 11:18 PM
  2. INSTALL WIKI for installing a new steering wheel
    Last Post: 11/29/2012, 02:22 PM
  3. steering stabilizer
    By Gussie2000 in forum VX Modifications...
    Last Post: 04/18/2011, 05:59 PM
  4. Independent4x
    By CrnCnn in forum VX Talk...
    Last Post: 11/07/2007, 06:11 AM
  5. INDEPENDENT4x...
    By Cyrk in forum VX Talk...
    Last Post: 04/11/2007, 04:10 PM
