Mine started having the same problem today....P1441 code. I'm going to try that and see if it works.
Three weeks ago I had my EGR replaced. That is what was thought to be my problem from a mechanic I took my VX to.
I used the search engine found several questions asked about it and a ton of different suggestions but no follow up as to what worked to fix it. Can anyone tell me if what caused it has been found? I know it is nit gas cap, I have done recent PVC and the fuel pressure regulator. No mods or anythging
Might your FPR be leaking a teensy-tiny bit?
I recently had same problem
Did a search for P 1441 code and found many suggestions to correct the problem.
Checked for vacuum leaks, wired disconnected and tightened the gas cap.
Went to Auto Zone and they reset the computer.
Check engine light off for now.
What is it?
Sorry for the unnecessary abbreviation...
FPR = fuel pressure regulator. I thought that if your regulator is not seated correctly, you might have a small leak in the fuel system that is caused the code? Maybe?
but it has been replaced and it was in for awhile before this started happening
