Results 1 to 5 of 5
Thread: Air Bag Cover
    Oct 2006
    2001 Ironman
    Air Bag Cover
    Has anyone ever replaced / removed the passenger side air bag cover without disrupting the air bag?
    can it be done?
    Mar 2006
    2001 FOXFIRE 0579
    i THINK, as long as battery is completly disconnected, i wont go off.
    Apr 2003
    2001, Ebony, 0761
    Exclamation Airbag
    Before you disconnect the wires to the airbag, make sure you are grounded to the VX. When the yellow connectors to the airbag are disconnected, a small piece of metal inside the connector (called a "Shorting Bar") drops across the two wires, bridging the wires together. This prevents the airbag fron discharging. No battery disconnect is nessessary as long as the shorting bar drops into place.
    I have removed many airbags from steering wheels, dashes, side bags, etc., without a problem.
    By the way, an airbag can be discharged with the power from a small 9 volt battery.
    Take your time, be careful and good luck.
    Howard (0761)
    99 White Ironman 1285
    airbag cover-passenger side of a 99--- the dash
    WE want to change out just the cover of the pass airbag. Does the cover pry off-is it attached to the bag or what. I have a dead VX with a perfect cover and want to change it out . Any further tips? Since I am moving I cannot locate my VX CD so I am kind of in the dark here. Thanks for any help
    Oct 2006
    2001 Ironman
    Bump
    just looking for help still....
  1. Car Cover
    By Lucian08 in forum VX Talk...
    Last Post: 11/07/2014, 10:36 AM
  2. MT Mag... VX on cover
    By Cyrk in forum VX Talk...
    Last Post: 05/13/2004, 11:27 AM
  3. Car cover for VX??
    By visconte in forum VX Talk...
    Last Post: 04/19/2004, 02:48 PM
  4. Car Cover
    By PBR in forum VX Talk...
    Last Post: 08/08/2003, 05:30 AM
  5. vx cover?
    By andy454 in forum VX Talk...
    Last Post: 07/07/2003, 07:16 AM
