Results 1 to 10 of 10
Thread: OME 913 springs
    Mar 2006
    OME 913 springs
    Am I understand correctly that OME 913 will give around 1" lift to the rear? My stock springs shrunk with the time, so I'm thinking to replace them with something (either OME or new stock springs) that will allow to fit TRXUS MT 265/75R16 or so in the future. I think this will give me enough clearance while not loose the driving comfort. I don't wish to end up with the spacers and don't wish extra lift, but I wish to let max suspension movement with that tires without tearing of fenders. Will 1" enough?
    Another question: Are OME 913 variable rate coils like the stock ones?
    1987 AMC Eagle: stock
    Arrow
    Quote Originally Posted by uncle_asa
    OME 912's give lift of about 2" or a little more & are single rate.
    They are about the same length as stock springs(with no load), just made of heavier ga. material.
    I know you don't want spacers, but that would seem the most economical solution. Also, cutting the rear bump stops in half vertically improves the ride a little.
    265/75x16" tires are approx. 31.6" in diameter compared to 29.5" for stock & should fit with a little trimming of the front cladding...if you're mounting them on stock rims.
    Mar 2006
    I'm going to replace springs anyway, so spacers are not the option. The options are: VX stock, OME 913, Trooper stock and OME 912. Cutting rear bump stops also will not improve clearance Just wondering what would be the best for my case (31.7" wheels in full diagonal crosses).
    I believe for the 265/75R16 the rims should be with ET20 (the formula I used is 38-(265-245)/2-((265*0.75-245*0.70)/2)*sin(pi/4)~=18, round to 20 )
    Red face
    Sorry dude...ya lost me there...I was a complete failure at algebra & just use one of many tire calculators available.
    Also, I've not seen OME 913's before, so I'm "in the dark" there too.
    1999, Ebony Black, VX ,1976
    those tires are 31.9" . shawn
    1COOLVX
    Mar 2006
    Quote Originally Posted by psychos2
    Anyway, the main question: will they fit freely with OME 913 or stock springs or not?
    Well if the 913's do give 1" of lift then I would say, yes, those tires should fit. Don't trim your rear bump stops though or you might stuff those tires into your cladding here and there. Give Rocky Road Outiftters a call or email them as they carry OME springs and probably have specs on all of them. Have you considered air bags for the stock rear springs? They might just be perfect for doing what you need. Maybe research that option as well.
    The tires will fit with no lift...just turn the t-bars a bit eliminating the rake of the vehicle and a very minimal amount of front cladding trimming should do. With the 913 (if they give 1 inch of lift) and a small amount of lift by turning the t-bar bolts you will be fine.
    I ran the same size tire (BFG AT's) with the first option for about 6 mounths before lifting.
    Mar 2006
    Thanks for the tip, wrote mail to them, let's see if they respond.
    The bags will cost like the new spring, so what's the reason to install bags?
    Mar 2006
    Quote Originally Posted by Triathlete
    The torsion lift is easy and can be adjusted even I miss from the first try, but I don't wish to miss with the springs height and install spacers. And I don't think I wish to go as big as you: if I ever go to the challenge I don't wish to contest with TLC on 36" with winch only because of I have tires bigger than 32"
    How it was without lifting? Does they stuff into the claddings on big rocks?
  1. Ome Springs
    By Lizardmen3477 in forum VX Modifications...
    Last Post: 07/29/2013, 12:11 AM
  2. Anyone near Hot Springs, AR?
    By VXobsession in forum Chit-Chat ...
    Last Post: 01/01/2012, 03:22 AM
  3. 912 Springs
    By UNEVEN THOUGHTS in forum VX Talk...
    Last Post: 01/25/2005, 01:18 PM
  4. Where to buy OME 912 springs?
    By coachreed in forum VX Modifications...
    Last Post: 08/12/2003, 12:28 AM
  5. OME 912 springs
    Last Post: 04/07/2003, 11:19 AM
