Results 1 to 4 of 4
Thread: supercharger peeps question
    May 2004
    99 Astral Silver w/ SC
    Anyone know where the supercharger oil fill and drain is? I see one plug right on the front but dont know if its the fill or drain or where the other is located.
    ----Trans Siberian Orchestra
    May 2004
    Used to own #777
    That's the fill plug. The drain requires that you unbolt either part of all of the nosecone. I'm posting because Joe B (bigpoppax2 on planetisuzoo) found a spring loaded coupler that will probably eliminate the "clicking" noise that many seem to have. If I were you I'd hold off on changing the oil for a few weeks until you hear from Joe about that coupler. It would be the perfect time to change the coupler.
    -Tad
    May 2004
    Excellent news Tad. Let me know when its posted please.
    You can remove the oil using a syringe with a small 1/8" hose slipped on the end. Auto parts sell these. I use about a 5" of hose. Keep slurping and poking the hose to the low point until no oil remains. Refill the correct amount. I found the level is about 3/8" below the edge of the fill hole when full. Filling to the hole will result in oil being forced out past the bolts and collecting in depressions in the gear cover.
    Roy
  1. Supercharger question
    By ScottinMA in forum VX Modifications...
    Last Post: 09/16/2014, 09:10 AM
  2. what say you, VX peeps?
    By Bob Barker in forum Ldub's After Midnight Topics
    Last Post: 04/29/2011, 07:25 AM
  3. Question for the Supercharger Peeps
    By Ruflyf in forum VX Modifications...
    Last Post: 02/09/2006, 03:38 PM
  4. Supercharger Question (noise)
    By t2p in forum VX Modifications...
    Last Post: 06/09/2004, 03:00 PM
  5. supercharger question...
    By technocoy in forum VX Modifications...
    Last Post: 05/23/2004, 09:30 PM
