What are you talkin' 'bout? Ride shotgun? You've seen the capabilities of a stock VX even with bald, skinny street tires!Originally Posted by biju
Yeah, I wouldn't have guessed they were 285.60's. Maybe the flames create an optical illusion?Originally Posted by biju
What happened to the pics though? They showed up alright yesterday.
Oops. I rearranged my gallery today - causing the url paths to break. I fixed them now...Originally Posted by Y33TREKker
-biju.
Better question... how do they do in the RAIN
DRY SURFACE:
One word: Smooth. The rubber is smooth, and has the added benefit of being noticeably quieter than the Terra’s. This was the strangest result for me, as I didn’t feel the Terra’s added much noise really. However, please consider that the Dragon (which had the Terra’s) had Dynamat installed. I have deadener for the Proton, but it’s not installed yet. Once that’s done, it should quiet the Dunes down even more so. The tires do not like grooves in the pavement at higher speeds (55 – 85mph), and give a good struggle to keep the VX straight – jerking the Cross from side to side. However, the width of the tire could play some role in this. Finally, the tires are have much grip giving the VX amazing agility and responsiveness around turns and quick maneuvers – very secure and surefooted.
MELTING SNOW/SLUSH/WATER:
I feel very sorry for the bloke behind me – and hope he/she has good wipers. These tires spew out quite the rooster tail of water! All around they channel water very well though, and give little play when faced with moderate water on the surface. They also do great when the small/medium puddle is encountered (good control). Watch out for water filled grooves in the pavement though – proves tricky.
SNOW:
EXCELLENT. We’ve had plenty of snow to test the tires in. They plow, and plow with ease! The Dune’s give good traction – thus little slippage. I like using the “Winter” option on our VX’s, but really there’s been little to no need for that with these tires. Unfortunately, the flames on the rubber are just for looks, and don’t actually heat up the road as you drive. Man, I wish somebody told me that before shelling out the pesos…
Admittedly, the 285.60.18 Dune Grapplers give the illusion that they’re smaller than the Terra’s of the same size (not as beefy) – as the wheel wells don’t seem as ‘filled out’ – at least not on our VX’s. However, so far the tires have impressed me handling water, snow and ice with tenacity. If the Terra’s are any indication of Nitto’s quality, the Dunes should perform excellent in Moab – my hope and expectations are high.
But I have a question for Chopper.
What would a quality color change run? Like say I wanted to go from my astral to a nice black pearl with a glossy clearcoat?
I actually have been seriously debating a colorchange, but I've had trouble finding info on a good quality colorchange (where you wouldn't know it was silver looking under the hood or opening the doors)
I'm sure it's expensive, but I have the feeling my VX is going to be getting driven less and less as a daily sinceI really do want to keep it forever and slowly do some preemptive restoring and customizing.
I'd love to hear your thoughts and opinions on a color change.
I do love the silvers dirt hiding properties and at one point had thought about just getting a nice wicked silver done over top of it all so to avoid all the prep work that goes into a complete colorchange.
Thanks Chopper.
macintosh man
...hands down - that's the cleanest example of a thread hijack I've ever seen. Well done.
-biju.
again I apologize
I just started typing!
I guess I could've titled a thread "hey chopper", but since he was here in the room, I thought I'd try and grab him. lol
I swear I'm not a message board terrorist!
Dood - no worries. twas my poor attempt at being funny.
-beej.
OK...Well, first; got my Dunes, love the look, but they just won't work for me. In Fla. there are two conditions we drive in. Wet,smooth, and Fast... and dry, smooth and Faster. Two lanes are posted@ 55-65, four lanes are mostly 70, which means we are pretty much all doing 65-90 all the time. Around here, the roads are well maintained, and glassy smooth, with looong straights and banking on the few curves we have. These things are too "squirmy" at speed, and since I don't go off road, they are now gracing a Wrangler that belongs to one of our metal men. A much better home in my opinion. The Michelin Pilots are working much better for me...laser tracking, great cornering, don't know about wet, but they ain't cheap. A little over 1700 with alignment and balance. Second:Wifey wanted me to look at that white one this weekend, for her. She wants it Purple! Cool by me, I'm thinking somewhere between old "Plum Crazy" and "Prowler Purple" but with a ton of dry Pearl and maybe a smidge of House of Kolor super fine gold flake in the clear. Glitter like a Bass boat in the sun and sparkle like a starry sky at night. I love doing totally inappropriate paint jobs! Figure all the prep (removing the glass, grill, door handles, lights,rack etc. interior,and dash, doors, all the stuff on the inner fenders and firewall...everything) at about 100 hours including stripping the old paint. Easy 40 hours priming, sanding, then cutting in the edges and insides. Two base coats, maybe one candy/clearbase, Three clears; next day 2000 grit it flat and give it three more clears and let it breathe a day or two...about 20 hours. Cut and buff out, 12-15 hours. Put it all back together, about 20 hours. About 8000 in labor and depending on type 3-4000 in material. Anything quoted at 2000 or so is a cheap scratch and squirt shoot... not what you want on a collector, more like Chevy Malibu. You can spend a LOT more...we,ve hung 40,00 on some nuts Viper... but not a whole lot less than 10000 for a real good shoot. Hope this helps answer some questions. Man this is a long post... but Hey... I was "jacked" Wayne
Chopper: Strange - mine are very solid at high speed (flat surface). It's just the large grooves they don't like. (here in colorado we have some nasty nasty road grooves). Did you get the same size (18")?Originally Posted by Chopper
-biju
Hey Beej, it wasn't the straights so much, as fast sweepers, and particularly the quick left- right transitions. I think the sidewalls are a bit compliant... probably a concesion to airing down, or absorbing sharp object impact. Don't misunderstand, they are awesome tires, big improvement over the "Stones" and if I hit dirt at all, they would still be on the VX. Yeah, they are 18's by the by.
