Results 1 to 10 of 10
Thread: Air won't blow
    Jun 2003
    2001, Green, VX, 0602
    Air won't blow
    Lately my 2001 VX won't blow air from the air condition or the heater whether it s on the hi or low settings or on auto. This would happen occasionally when I'd try to switch it on while driving but now my air won't blow. I hear a click as if something has engaged but no air blows out. When the vent is open hot air or cold air will blow through at the temperature I set. Any ideas? Has anyone experienced this?
    don't hate
    1999. Unique Ironman
    most likely vent motor broke i had exacly same problem on my 99 VX, dealer fix it under warranty
    Arrow
    Probably a long shot but,...check the fuse ?
    Dec 2004
    1999 Ironman
    your resistor has come unsoldered under the dash just happened to me a few months ago, easy fix if you know what you are doing
    Jun 2003
    99vx4x4, unfortunately I don't know what I am doing... Today air blew through the vents so this sound like an on an off thing but I can just imagine that it decides not to work on one of our many 100+ degree weather days... so weird...
    Dec 2006
    1998,SILVER,VX,1174
    Hi Kobie,
    You Might Also Like To Check The Relay In Main Fuse Box Under Hood.
    Swap It With The Horn One Just To Test It Out. You Never Know?
    Hope You Get It Sorted Soon.
    Happy Vxing. Mike
    NC 1999, ironman, 0358
    Arrow
    as he said a couple of posts above this one.
    It happened to me too...very maddening it was summer in Atlanta...very hot...really motivated me to fix promptly...it was that resistor had become unsoldered. a search should yield the procedure but it was (as I recall) something like this...remove glove box...remove door to blower motor...remove small box...cut it open (plastic, hack saw works fine)(or maybe it hade a door to remove and no cutting needed)..resolder the lifted metal tab. Made me feel good to save big bucks on a relativly simple fix.
    Western North Carolina...
    Veni, Vidi, Velcro
    Jun 2003
    Finally fixed after 1 year...
    After I posted this issue it went away until 3 weeks ago- probably the very day we got the 100 degree heat in Houston. It turns out my issue was both the blower motor and the resistor. The old blower worked after running the car for over 40 minutes if at all. I got a resistor from a junkyard and the blower would still only work intermitently. I got a new blower motor (Siemens brand that doesn't fit as well as the old one) from Autozone and replaced the old one but also put the old resistor back in and the air conditioning would only work on the highest setting. Coupling the newer resistor and new motor was the only way to get my air conditioning to work on all settings. Here are a few lessons learned from trying to get all this done:
    1) Autozone carries the wrong blower motor resistor for a 2001 Vehicross. The resistor, which is special order only, fits only the 1999 and 2000 year models though it is labeled for a 2001. As far as they could research in the store, they don't carry a replacement for the 2001 models.
    2) All late model Troopers, Rodeos, Passports and Amigos use the same blower motor resistor as the 1999 and 2000 Vehicross models.
    3) From the looks of the 3 prong resistor opened up, it is difficult to tell that the resistor is actually blown. My working and semi-working resistors looked the same when the plastic cover was unveiled. Nothing looks like it needed to be soldered.
    4) As an amateur do-it-yourselfer, I found it difficult and awkward to remove the bracket carlymac mentions in the thread linked before this post without totally removing (unscrewing) the glove compartment. Also, the bolts are 10mm and I couldn't get my english tools to remove them. The blower motor was difficult for me to screw into place but, again, I am a novice and a pretty big guy for that tight space.
    5) I probably would have been better going to the local dealer (or Merlin) to get my parts or get the work done but they've gotten enough money from me this year and I was trying to fix my air more sooner that later.
    Aug 2007
    2001, Proton, VX 1394
    A/C woes
    well u guys have your A/C problems, mine's a bit different.
    i can turn my A/C on with the slide all the way in the blue (to the coldest setting) with the recirculate on windows up and it being a cool day.... my A/C is HOT air??????
    i don't get it... one of my buddies said i probably had a puncture and all my refridgerant leaked out, and it cant cool without that, i know that much.
    Richard
    Proud owner of a RWD VX
  1. Giant blow up VX
    By Scott Harness in forum Chit-Chat ...
    Last Post: 06/27/2013, 07:14 PM
  2. wish I had 150k to blow
    By maxprime in forum Chit-Chat ...
    Last Post: 03/05/2012, 01:22 PM
  3. its so tempting to blow this money /rant
    By pbkid in forum VX Talk...
    Last Post: 03/06/2009, 12:07 PM
  4. Gas Milage Goes from Suck to Blow
    By ojmagg in forum VX Troubleshooting...
    Last Post: 03/01/2007, 05:33 PM
