Sure is. I didn't, but you just have to find that reverse line up front, or run a new one for the back.
When I put mine in I ran a few extra lines to the front for future options
Andy C
01 Firefox VX
CT
isnt revese signal is only one wire?
You should be able to run it right off of the backup lights in the rear. The only problem is that the front would remain on all the time unless you found the reverse wire up front like AndyC said. Another issue with doing it that way is that the screen takes a second or two to turn on, get set up, and adjust the brightness. It also isn't that great for using just as a backing up camera due to its wide angle. You can see a lot to the sides, but the depth perception is piss poor in this thing. I know that sounds kind of contradictory, but it is pretty hard to use for say backing up into a trailer or parking spot, etc.
well my camera connected to my back up lights and i didnt figure out yet where im going to connect my screen because its 2 wires red and black which mean positive and ground and reverse signal is only one wire red w/yellow stripe so it would be what?
I installed my camera into VX stock hole and i can see a little peace of my body so i know exacly how close i am to the other car and thats what i was looking for.
I love this thread!
I've often thought about hardware hackin a used digital camera with a built in LCD. Put the LCD on the dash and the rest of the camera in the back. All it would take is some shielded wire. Wire up a shutter switch and you can snap pics of where you've been!!
I've liked the idea of a cam in the back of a VX ever since I saw one here, while researching my lastest theft errr errm, purchase of a VX.
way cool mod!
Thanks for all the help.
