Originally Posted by
Ldub
That big silver (aluminium) thing under the plastic cover, on top of your engine is the intake manifold...
Remove the plastic cover so you can see what you're doing, remove the friction inserts from the plastic cover mounting pegs & re-insert into the mounting holes on the bottom of plastic cover.
Look at where the intake manifold connects to the heads...that's where your intake gaskets are.
Start your enging from cold (let it warm just enough to idle normally) & spray carb cleaner, starting fluid (ether, my personal favorite), or brake cleaner where the intake gaskets are & listen for any change in rpm.
Put it all back together & call Merlin for new intake gaskets.
Just to clarify one point - what you are describing as the intake manifold is actually two pieces, sealed by a single gasket. I think the top part is called the "common chamber". The intake manifold connects to the heads in two places and uses two gaskets. You most likely will NOT have a leak in that "upper" gasket (between the common chamber and the intake manifold), but if you are thinking about replacing the intake manifold gaskets, removing the common chamber may make it easier to get to the intake manifold. The leak will likely be lower down, on one side or the other (probably not both), where the intake manifold connect to the heads (look for the edge of the gasket).
