Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
Thread: rebuild
  1. #31
    2001 Ebony 0177
    Was this a '99 block, you started with? Did you run it in on the bench, or are you just plunking it back in? Did you change (or clean up) any oil ports? With the reported oil starvation issues in the '99s, opening them up some would have been prudent. One more thing, how dirty was the intake and all? (I don't care for this EGR/Cat setup-suspect it takes too long for the cats to light up, dumping more carbs back up top) Cool, you're almost rollin'__Wayne
  2. #32
    Its a 2001 model.
  3. #33
    Shes running like a top. All is well and the VX is back on the road. I have to say that reinstaling the motor was the hardest part. The removal was cake, the build was also cake but the instal was the most tedios pain in the *** thing I think ive done in a long time.
  4. #34
    Well, the rebuild is a complete success. Now that ive done it im offering my services for a complete rebuild of blocks, short or long, removal and install. Turn around on removal, rebuild and install will be around 3 weeks.
    Only the long block- $1200 labor plus parts and machine
    Complete engine removal, rebuild and installl- $3200 plus parts
    Total cost for rebuild parts
    $850 for rebuild kit
    $500 for machining
    Porting and other mods can be negotiated
    A down payment on parts and machine work wich will be determined after all of your original parts are inspected.
  5. #35
    2001 Ebony 0177
    Quote Originally Posted by MoonRaker
    Try changing the starter on an old #!@*# Z3....yanking the engine seemed a viable alternative.
  6. #36
    2001 Ebony 0177
    This is more what I have in mind.........[img]1.jpg[/img]
  7. #37
    Yeh im thinking of a swap down the road, maybe going diesel like a V6 powerstroke.
  1. Shock Rebuild
    By ironmikevx in forum VX Talk...
    Last Post: 12/10/2015, 02:49 PM
  2. abs rebuild
    Last Post: 12/13/2014, 12:44 PM
  3. abs rebuild
    Last Post: 10/28/2014, 02:04 PM
  4. rebuild oil
    By steelzeus in forum VX Talk...
    Last Post: 04/20/2006, 05:35 AM
  5. KYB Shock Rebuild
    Last Post: 06/08/2005, 09:04 PM
