Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
Thread: Fuel Pressure Regulator
    2000 IronMan #11
    Fuel Pressure Regulator - I love my VX again.
    Im pretty sure mine is failing, I am running too rich. Question is how easy is this to replace? And honestly I do not know of its exact location or what it looks like. Trust I am a quick learner.
    Any help?
    Also should I go ahead and buy from St. Charles or another distributor?
    Thanks.
    JRH
    2000 IronMan #11
    Consider it read. But how easy was the install? On a 1-10 scale.
    2001 Proton VX 0790
    What make you think you are running too rich, and why do you think its the fuel pressure regulator?
    John C.
    Mar 2006
    Quote Originally Posted by JHarris1385
    Any help?
    Thanks.
    Pretty easy if you have tool to remove internal ring grommet (??? see pic below ) something like that:
    Just in case you want go with aftermarket, do not buy Standart Motor/GP Sorensen unit, Neihoff/Borg Warner should be fine. They are available in Checkers at least.
    1987 AMC Eagle: stock
    2000 IronMan #11
    Thanks alot. My previous post(s) conclusions led to the FPR. I have a tool similar, for use on the John Deere. Thanks. SHould I order from St. Charles?
    2001 Proton VX 0790
    This is the FPR showing correct assembly, and part #. its at the drivers side rear of the injector fuel rail.
    John C.
    Mar 2006
    Just compare price from Checkers and Isuzu and select cheapiest source. I think it is exactly same part in different packages (Neihoff/Borg Warner/Isuzu).
    Feb 2004
    '01 Ebony #0830
    Just curious...
    Has anyone ever tried an adjustable fuel pressure regulator?
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    Wink
    Quote Originally Posted by SilverBullet75
    Check the "similar threads" @ the bottom of this page & you'll find what you're looking for.
    2000 IronMan #11
    So I finally got my FPR in mail today from drivewerks.com. But I come home to find out that my retaining ring pilers tips are too large to fit through the holes.
    Question is are these pilers easily purchased at HD or Lowes in smaller tip sizes?
    Mar 2006
    In worst case you can use file on what you have But I think HD/Lowes/Sears should have them in right size.
    2000 IronMan #11
    Bought some new ones with multiple tips and angles. They are great. BUTTTTTT. Iv got the fuel rail almost completely off and can not get the bolts that attach the black cover over the fuel pressure regulator unbolted from the common chamber. Even PB blaster has not worked yet.
    Ill post pics later, if you all do not know what bolts I am talking about. They are completely round and require a large allen wrench. Talk about leverage with an allen wrench.
    Has anyone done this repair yet?
    Mar 2006
    If I understand correctly, you talking about the bolts marked as 340 here:
    Mine bracket was holded with the internal hex on the side and regular metric bolt on the rear actually The side bolt was replaced with the regular bolt at the end, though - I also almost rounded it with not 100% fitted tools
    2000 IronMan #11
    Nice diagram, where did you pull that from?
    I gave up on it for now going to try tomorrow maybe the pb blaster will soak in more by that time.
    I almost busted the allen wrench trying to lossen it.
  1. fuel pressure regulator, missing hose
    By SEBACOQUI in forum VX Troubleshooting...
    Last Post: 04/08/2013, 01:04 PM
  2. Fuel Pressure Regulator
    Last Post: 04/07/2009, 05:24 PM
  3. Fuel Pressure Regulator Replacement
    By Dino in forum General Tips...
    Last Post: 09/25/2007, 09:24 AM
  4. fuel pressure regulator?
    Last Post: 04/07/2006, 06:15 AM
  5. fuel regulator SC/5psi?
    Last Post: 06/20/2004, 09:06 PM
