Results 1 to 7 of 7
Thread: Belt tensioner
    Feb 2005
    2001 Ebony VX 0448
    Belt tensioner
    How much effort (relatively) should it take to move the serpentine belt tensioner to remove the belt? Am I correct in assuming that a ratchet on the tensioner pulley nut clockwise should rotate the tensioner to release tension? I am afraid that my tensioner is frozen or else I'm not using enough effort. If frozen, how is the tensioner removed for replacement, i.e., how is the tensioner attached to the block, I don't see a bolt.
    Apr 2006
    2007 Suzuki V-Strom 650
    I usually use a breaker bar or a cheater bar to move tensioners back. Those springs are pretty tough. If it's frozen, you should be able to get it off by removing the torx bolt in the center then wiggle it out by lightly prying or tapping on the pulley end with a hammer. Cutting the belt might help. You should replace it anyways if you're replacing the tensioner, since it might be overextended already.
    One tip: buy the best quality torx sockets you can afford. Cheapies will cause them to strip out at which point you are screwed.
    Another: if you have room, put the torx socket in then tap it with a hammer a few times. It both helps seat the socket better and release some of the binding force on the threads.
    Edit: actually now that I think about it, I think the tensioner is held on by a metric allen bolt. Same rules apply though. But, make sure you don't try a non-metric allen head - it will strip.
    2001, Ebony Black, 1153
    Did you check this thread?:
    http://www.vehicross.info/forums/sho...1&page=2&pp=15
    LDub gives a nice little drawing explaining it, as I remember it was tough but not that tough last time I did it.
    Feb 2005
    2001 Ebony VX 0448
    Breaker on the nut on the pulley. (I found an exploded view of the tensioner assy that shows it's mounted to the block by a bolt on the left side so removal is feasible.) I just don't want to break it if it isn't frozen and am concerned how much effort it should take to move it.
    I have a spare if your's is trashed - email me.
    Apr 2006
    It should move fairly easily with a breaker bar. I mainly use one so I can hold it back with one hand while I put the belt on so I don't lose a finger.
    1999, Ebony, 0797
    I hate it when I lose a finger.
    Although for some reason people are frequently willing to GIVE me a finger...
    :sigh::
  1. Best timing belt,water pump,tensioner etc...kit to get
    By bigblock8396375 in forum VX Talk...
    Last Post: 04/07/2011, 11:26 AM
  2. Engine Knock Vs. Timing Belt Tensioner
    Last Post: 01/01/2011, 06:11 AM
  3. Goodyear belt tensioner part number
    By VXNIT in forum VX Talk...
    Last Post: 10/06/2010, 08:05 AM
  4. Dead tensioner
    Last Post: 11/21/2007, 01:49 PM
  5. Serpentine Belt Tensioner removal
    By Maugan_VX in forum VX Troubleshooting...
    Last Post: 08/22/2007, 06:23 AM
