Results 1 to 8 of 8
Thread: Need info for Tranny and TOD fluid and Filter change..
    Aug 2004
    01, Kaiser Silver, VX, 1102
    Question Need info for Tranny and TOD fluid and Filter change..
    Can I get some facts from the experts before beginning this adventure?
    Mobil 1 Product for Tranny and TOD?
    Filter and Gasket Specifics for tranny? Buy from Isuzu or other location and Go with Cork or Neophrene gasket composite?
    Capacity-Quarts that go in tranny if flushed and filter change?
    Capacity-Quarts that go in TOD.
    Tool used for flushing Tranny and where to get?
    Filler or pump gadgets to assit refill?
    Also any reco on radiator flush tools and type of antifreeze or mixtures for my Daytona Beach driving?
    Thanks
    Aug 2006
    1999, Astral, Vehicross, 1619
    I am in need of the same info.
    Aug 2005
    1999, silver, 0887
    Joe Black has written a nice piece on this subject. If you need to know more, my personsal experience on this subject has been very involving, to say the least. PM me and I'll call you to discuss the ins and outs of getting this job done right by a service supplier.
    Mar 2006
    Workshop manual says that tranny is keeping some info on oil quality, so it is better be reset with the scanner after oil is replaced. I did not reset it and no major problems on 15K, but I also did not replaced filter (my mechanic told me that it might cause lot of problems if you put any dirt there, so he refused to change it by himself). I'm going to replace filter and oil again, and reset the tranny during next 5K.
    1987 AMC Eagle: stock
    99' Astral Silver
    Is that some some sort of special tool he's using to adjust the headlights? That was new to me. Also, I'd like to see if we can get our hands on that card he said came with the video on cleaning and painting the cladding.
    Live Free or DIE!
    I bought an OEM filter with cork gasket from Autozone. Ran me about $35 iirc. One tip, if you go this route, take out the cork gasket and put it between some big books or some other flat heavy objects for a couple days. It will make keeping the gasket in place during installation a lot easier.
    Getting new fluid up into the fill hole is a WHORE to say the least. I used a little hand pump from Pep Boys to do the trick. Its messy as hell.
    Also, I used Mobile 1 Synthetic tranny fluid. My trans fluid was chocolate and burnt smelling when I bought my VX. I was also slamming gears hard inbetween 2nd and 3rd. Changing out the fluid fixed this problem.
    PS - To change the filter you will need to drop the crossmember supporting the tranny. You have to use jack stands to support the trans first, and then drop the cross member. Try to find a buddy to help you with this project, and give yourself all day or all weekend...
  1. I need info on my tranny, How to check fluid??
    By VehiTONY in forum VX Troubleshooting...
    Last Post: 08/19/2014, 04:38 PM
  2. Transmission Fluid Filter Transfer Case Fluid Change
    By driver3 in forum VX Troubleshooting...
    Last Post: 09/16/2005, 03:23 PM
  3. tranny filter change 30k service
    By xiaoz in forum VX Talk...
    Last Post: 01/06/2005, 08:55 PM
  4. Tranny fluid change
    By curiosdv in forum VX Troubleshooting...
    Last Post: 11/09/2004, 09:59 PM
  5. Replies: 5
    Last Post: 01/12/2004, 06:42 PM
