Results 1 to 15 of 17
Thread: Differential drop brackets
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    OK, who has done these? I am trying to figure out what thickness metal to use for extending the brackets. They seem to be around 3/16" thick but with reinforced areas where the 4 bolts come through. I want to play it safe and use something that will hold up well, especially since it will be adding leverage between the mounting points. I tried PMing some people who had done this mod, but their PM boxes were full. I am trying to do this this weekend, so any help is really appreciated. Also, what is the general consensus on the best drop distance? I have heard the DOR mounts were 1.5" and I know BigmeatVX said he went with 2", and some people are saying to go as high as 2 1/2"-3".
    2001, IronMan White, #440
    I would like to do this mod too. Are you going to make some yourself? I might be interested if make some extras.
    Peace.
    '99 Ebony VX #0038
    Hey Ascinder -
    I have a set of these, still brand new and not installed, from Independent4x. Send me an e-mail with your questions and I'll do my best to answer them. I can send pictures and measurements or whatever.
    Kyle
    P.S. - They're NOT for sale, so don't even ask!
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    Quote Originally Posted by kpaske
    LOL, you seem to have caught on quick All right, I sent you an email.
    And to answer the question of whether or not I can fab up some extra mounts, I am modding my stock ones, and have no idea how they will turn out , so what I'm trying to say here is that you would have to pull yours out, send yours to me to have done, then trust a guy that has only built one set with no testing to prove they will hold up, and I'd make you sign a legal disclaimer that kill several trees just to print it , but if you're OK with that, then sure I'll do it. I am actually just finishing up building a heavy duty tie rod which I had planned on offering to the VX community.
    Jan 2006
    Question
    indy4x sells them? I havnt seen any on there site?
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    I asked that same question when I emailed him, but he realized he got them from DOR which is extinct so don't get any hopes up. Looking at the pics of the DOR mounts, they look very similar to the ones BigmeatVX fabbed himself. That makes me feel better, and I think I may be attempting this tomorrow morning. I just finished doing my HD tie rods, with pics to follow soon. I can't believe I used the wrong tap when tapping out the first one though. I knew I should have put it away, but I forgot, and ended up threading about 3/8 into the rod. Fortunately I still had to chop 1/4" off of it and had some titanium putty lying around to fill in the few threads remaining. So they will both be finished tomorrow morning after they get powder coated.
    Arrow
    Just a FYI as I haven't seen it mentioned yet...but for every inch you drop the diff, you also lose that much ground clearance.
    Just me thinkin' out loud.
    But!!!!!!!!!!!!! The dif drop will allow you to lift a bit higher without trashing your CV's, thus allowing bigger tires, thus allowing more clearance.
    Arrow
    Hey, I'm just sayin'...
    It would be something I'd consider if trying to decide how much of a drop I was going to be fabbing.(somewhere between 1-1/2 & 3" as posted earlier)
    Thats why one day I'll be SAS'd!
    By the way THIS PLACE sells drop brackets and a lot of other things for the VX...you just have to be able to decipher the Japanese language!
    Mmmm...I dunno...I kinda shy away from buying anything from a place where all the part numbers begin with POS.
    Quote Originally Posted by Triathlete
    Good point, however...you have to increase tire diameter by two inches to gain back one inch of ground clearance.
    Oh utopian suspension that does it all...where are you ?
    Jan 2006
    **Translated** ...somewhat... and good luck with the prices. that drop bracket is a bit more than $400+shipping from Japan.
    '99 Ironman, 0992
    Also keep in mind the front drive shaft does not have any kind of slip-yoke to adjust length. If the front diff is dropped too much you will need a spacer machined or a custom shaft. The front shaft does not use typical u-joints either, so changing the angle of the shaft can induce some vibration. Mine did with a 2" front diff drop. I helped it a little by making the mounting holes on the drop brackets alter the pinion angle a few degree, but it was still there.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    OK, I'm about to go out and start taking stuff apart, and I think I may just shoot straight for 3", I will probably have to make up a spacer for the driveshaft though, how did you solve this vibration issue with yours?
  1. My Diff Drop Brackets!
    Last Post: 06/08/2018, 07:42 PM
  2. Differential drop?
    By Boonetown123 in forum VX Talk...
    Last Post: 09/07/2014, 05:49 AM
  3. Diff Drop Brackets
    By UWVX89 in forum VX Modifications...
    Last Post: 11/18/2012, 01:06 PM
  4. Diff Drop Brackets
    Last Post: 04/04/2011, 07:40 AM
  5. Diff Drop Brackets
    By ZEUS in forum VX Modifications...
    Last Post: 07/29/2008, 11:18 AM
