I was getting the P1171/P0137/P0157 combination codes a few weeks ago. I cleared the codes, but they kept coming back. I did a search here and came up with several possible causes -- intake manifold gaskets, O2 sensors, MAF sensor, EGR, fuel filter, gas cap, etc. I tried the simple stuff like tightening the gas cap (I knew it wasn't that since the errors occurred before AND after a fill-up), checking the EGR nut, and listening for whistling intake leaks. After a week of failed cures I arranged a dealer service call. They have been good to my VX and me.
Their fix - replace MAF (most likely culprit - oil from the K&N filter. Probably should have tried cleaning this out myself), clean EGR, throttle body and fuel injectors (at 101K probably overdue anyway.)
After a week the CEL has not returned, throttle response is greatly improved, and mileage... still sucks!
The engine never ran bad. No rough idle. No stalling. So the TSB for intake gaskets didn't seem to apply here. The light always came on during moderate acceleration up a long, slight incline from a stop. I had done a few full-throttle passing maneuvers on flat roads without triggering codes. Normal acceleration on flat roads from a stop was OK, too.
Just wanted to add my experience for those searching for a solution to their CEL. Clean the MAF, EGR and throttle body.
Gregg
2001 Proton Yellow #1379
