Results 1 to 7 of 7
Thread: Another Window fix
    Another Window fix
    I just got my 2000 VX and love it ... BUT ... !@#% windows.
    My driver side window was so bad that the rubber stripping actually bunched up in front of the window and eventually tore. That prompted what may actually be the best fix for the recurring problem:
    Cut the rubber where the front window frame meets the door & remove the entire lower portion. Throw that piece of junk as far as you possibly can. Use felt weather stripping from your local hardware store to line the track all the way down (glue in place using weather strip glue or RTV). Trim excess for asthetics. You may need more than one layer for a tighter fit but right now I only have one. I'll be making a 6 hour drive at highway speeds this weekend so I'll let you know if this created any wind noise. So far this trick seemed to work. I'll post again if I encounter any problems.
    P.S. The whole process took me less than 20 minutes to complete.
    99' Astral Silver
    Is this fix water resistant?
    I would imagine you'll be getting water down in the door that will eventually lead to rust.
    Live Free or DIE!
    Nov 2002
    Question
    Are you talking about the guide rail inside the door or the forward portion of the outside weather seal?
    2000 IronMan #11
    Post pics.
    Felt fix
    Sorry it took so long to get back to you on this - work got in the way.
    I did in fact get wind noise at highway speeds so I'll be adding some more felt to get rid of that.
    I'll try to take some pix of the fix this weekend. Actually, I'll try to take pix as I do the passenger side.
    So far no water intrusion that I've noticed but will keep an eye on it. If you do the fix as I described it though there shouldn't be any more water intrusion than the factory design.
    2000,VICTORY WHITE,VX,0101
    window problems no more?
    As I mentioned in another thread I was going to use my Sticky Putty I bpught off HSN.COM and the stuff works!!! I have used this on all kinds of stuff and my god I think my window wow's are a thing of the past. This stuff is like a two part epoxy that when mixed together it makes the most incredible bond to anything. I took pictures of the finished project so if anyone wants to see what it looks like send me you email and I will send you some picts.
    Thank God for Sticky Putty...it rules!!!
    May 2007
    2000, Ebony Black, ....
    Quote Originally Posted by tom4bren
    I think you've cured acne by decapitation!
    Thanks for all the help.
  1. Window Fix
    By VXRick in forum General Tips...
    Last Post: 10/12/2016, 10:01 PM
  2. Replies: 1
    Last Post: 01/11/2012, 02:45 PM
  3. window fix
    Last Post: 09/09/2011, 09:29 AM
  4. Window Issue - Regulator and Window Strip
    Last Post: 01/13/2009, 11:31 AM
  5. Window
    By VehiP&J in forum VX Troubleshooting...
    Last Post: 05/06/2004, 07:34 AM
