Results 1 to 15 of 15
Thread: Lift thread to end all lift threads
    Some of us contemplate an SAS and I have heard someone who knows someone who has done it but I have never seen any proof that a solid axle VX exists! I have seen Troopers and Rodeos and Amigos with a solid axle swap though and they perform rather well offroad. I can't make up my mind if I should do it or not, but Triathlete is all about doing it, SPAZZ has started collecting parts for it, Alaska VX might be underway with his, Dstruction might already have done it...
    Back to your original question. Ascinder posted some info on these adjustable coil mounts sometime ago and I think he installed them on his VX with good results. These would allow you to keep your stock coils and give you the ability to fine tune your lift height in the rear - then you just crank on the t-bars until the VX sits the way you want! So you have the option of lifting your VX 1" then 2" and then back again, all by turning a wrench or two!
    There are things you should do to your VX when you are adding bigger tires though. Like Ldub mentioned, get braided brakelines - but I suggest also getting HD tie rods bcuz the stock ones are WEAK! And if your VX doesn't already have them, get the f/r greasable poly swaybar bushings. Otherwise, yes, it is just as simple as cranking the t-bars to lift the front and adding either a poly coil spacer, or the adjustable coil mount, or new coil springs, or all of it, to lift the rear. The rest is just stuff to go along with your now lifted VX - bigger tires, brake lines, tie rods, bj flip, poly bushings - then the optional stuff... deeper gears, lockers, locking hubs, front axle diff drop brackets, stronger control arms, extended panhard bar, shocks, bump stops - then the toys... winch, rocker guards, bumpers, diff guards, skid plates, roll cage, solid axle, lower x-case gears, welder, on-board air, etc............ and we're broke
    Keep us posted on what you decide!!
    There is no completed SAS that I know of. Spazz started colecting parts. Spazz was planning on using leaf springs. D Struction sold his VX to someone on this board (sorry, can't remember your name) in Alaska and it does not have an SAS...only a suspention/body lift.
    WHEN I do mine it will be a linked suspension. Cost will depend on how much of the work you can do. I plan on doing all the prep work on mine but since I don't weld I will leave that up to the pro's (especially since my life could depend on it).
    May 2005
    '99 Victory White Ironman #0194
    I have OME 919's on mine. about 2 1/2 - 3" of lift (dont remember exactly). the extra stiffness gives it the same riding charactersitics as stock, only taller.
    I know of two shops that are up to an SAS project. I would probably go with Stric9 (darkengineering) if and when I could afford it.
    1999 Lotus VX Ironman Edition
    It's fun to rebadge...
    If your shocks are worn out this would be a good, although expensive, lift option: http://www.independent4x.com/item.ht...3&PRID=1554300
    Add the HD tie rods and you would have a great setup. I would still consider adding a longer panhard bar or a new bracket for the stock one, as well as a front diff drop, when adding this much lift.
    1999, Black, VX
    One of these days I'm going to swap over to a linked solid front with coil overs front and rear. But that will be once I get my RAM Powerwagon. I'm still recovering from all the work we did to my VX. Everything is still running fine and I'll have some new pics soon. I've been way to busy with work and starting an industrial salvage company.
    As far as an uber lift I don't know what to tell you. It all depends on the kind of stuff your going to be doing. Like, is it going to be a daily driver or purely a trail truck? Do you like having good mpg? What size tyres do you want to run? How hard do you hit off road? So on and so forth. Once you figure all that out you then you can figure out how to make the uber lift for you.
    Custom Independent4x 4.5" suspension lift, Custom Independent4x 3" body lift, 36x13.50R16 Irok radials, 16x8 American Racing Mojave teflons, Warn locking front hubs, Independent4x extended braided brake lines, Independent4x heavy duty tie rods, Calmini extended bump stops, Calmini extended brake line brackets, Rancho RS9000X shocks,1.5" wheel spacers, And trimmed cladding
    Aug 2006
    2001 Proton VX 0136
    Thanks so much for the help guys, the overwhelming response is very appreciated. Sorry for my delay in getting back to you...been in Vegas on biz for a week and have my big annual tournament on Memorial Day that I am pulling my hair out for.
    Zues, that is a tremendous link you sent me in your post...looks to be pretty much everything a guy needs, the ease of the calmini (everything in one place) but with no fluff, and a lot of the stuff that you all said I would need/should get (braided brake line, bump stops, poly spacers, ball joint spacers, etc). Would that particular kit fit the VX with little/no modding?
    To answer your ?s, sadly, I must admit that I am not a hardcore offroader. As much as it pains me to say it, I watch some of the videos of Moab and cringe at putting my Proty through that, though I know they can mostly handle it. She will not be an every-day driver, she will pretty much be a tricked truck. I want her to look oh so sweet! I have done this before, when I was poor(er) and only 16 with my Ford Ranger. I learned from that that look is fine, but function is better, even if not used. Everything was for looks. It was 2WD but had a 3" lift...which was all body, no suspension. Had a nice hood...all hood scoop, no function (weak little 4.0 V6 under the bonnet). So from that I have learned that if you are gunna do it, do it right. Though I think your truck might be a bit tall for me. And I don't care about MPG...technically, *cough* I use my company card to fill the tank since I got the owner's permission since I do so much running around for the company. So, while I will not be driving it that much anyway, fuel economy is not a worry for me.
    I would pretty much want to run about 33" (maybe 34s) under her. With enough lift to accommodate that big of a shoe and still be able to steer her, I think it would look great without being too much.
    As far as power goes, get this, I have got my mechanic looking for a nice, low mileage, diesel for me. To me, there is nothing like a turbo diesel. Power, speed, torque, and god I love that smell!
    Quote Originally Posted by tbigity
    Zeus, that is a tremendous link you sent me in your post...looks to be pretty much everything a guy needs, the ease of the calmini (everything in one place) but with no fluff, and a lot of the stuff that you all said I would need/should get (braided brake line, bump stops, poly spacers, ball joint spacers, etc). Would that particular kit fit the VX with little/no modding?
    That kit is for the VX and later Troop so the only mods needed should be the removal of old hardware!
  1. To lift or not to lift that is the question
    By CatFish in forum VX Talk...
    Last Post: 03/28/2012, 03:15 PM
  2. VX Lift
    By ramil89 in forum VX Talk...
    Last Post: 06/07/2010, 09:51 PM
  3. lift set up
    By pbkid in forum VX Modifications...
    Last Post: 04/12/2008, 01:25 AM
  4. lift?
    By Johnny108 in forum VX Talk...
    Last Post: 04/08/2008, 09:56 PM
  5. A little help...LIFT?????
    Last Post: 03/03/2008, 09:35 AM
