Thinking about buying a V CROSS, need to know the towing capabilty for the truck, thanks
if you do a search of the forums you will be able to find a lot of information.. the short of it is this...
there is a tow hitch available from uhaul rated at 3500 lbs and a member here offers a different option that he has tested up to 5000lbs, there is no official towing capacity for the VX but on a tropper with the same engine and chassis, the towing capacity is 5000lbs so the VX can handle it, but you must be careful because the VX has a very short wheel base which makes it somewhat more prone to jack knifing if you arent experienced at towing
Thanks for the info!
