Results 1 to 2 of 2
Thread: tod"check"lite blinking after rollback in neutral to drive,is this serious or ez fix
    Sep 2006
    1999black0419
    Question tod"check"lite blinking after rollback in neutral to drive,is this serious or ez fix
    shifted into neutral ,rolled back on hill,thought i was in drive,tod "check " lite came on.wouldshifting into 4 lo briefly reingage system?
    2001, Proton Yellow, #0580
    Pull off the negative battery cable for 5 minutes or so - it'll reset everything and you're TOD light will go away. Of course, if something serious is wrong with it it will come back on, but I've had something similar happen to me - engine went dead slowing in a wide curve - I put the truck in neutral and restarted it - when the tranny engaged in drive the TOD light came on. Did the reset and it went away, no harm, no foul.
    -- John
  1. odometer "rollback calculation" ?
    By louweed in forum VX Talk...
    Last Post: 08/01/2015, 05:12 PM
  2. Replies: 35
  3. TOD "CHECK LIGHT"...intermittent at 60mph plus
    By JoFotoz in forum VX Troubleshooting...
    Last Post: 04/06/2009, 07:00 PM
  4. What is "NOT" needed to drive your VX
    By Dumke in forum VX Talk...
    Last Post: 05/18/2008, 12:40 PM
  5. "Wood" you drive this?
    Last Post: 02/21/2008, 08:05 PM
