Results 1 to 15 of 15
Thread: Long drives and engine codes....
    Mine does this too. Anytime I clear the code it comes back on within a day - usually. I went 3 months with it off until the last Moab trip - it has been on ever since. I already know it will go off again within a month, but I don't know what code it throws.
    Dec 2004
    '99 VX Astral Silver #0949
    Question Check Engine Light
    My Check Engine Light came on this evening, and twice I popped the hood looking for problems. I can't find any! Even the air filter looks clean! The only fluids consumed are the winshild wash fluid and fuel. No oil usage here.
    No performance problem that I can notice, but I don't no what sensor could be the problem?????? Huh????
    I guess I will pull the battery for 15min and see if it resets itself.
    Mar 2006
    2001 FOXFIRE 0579
    a word of caution, but dont know how reliable it is,
    i was told that because of my code 1171, lean on acceleration, the computer was dumping too much fuel into the engine, and that that fuel was combusting in the cat converter, and in a matter of days destroyed my cat. converter..........
    bulldoggie, get the code read before you pull that battery, if its not too late.
    Dec 2004
    No Isuzu dealer nearby, I think someone said Autozone will read them?
    Do they charge a fee for reading codes? Will NAPA read them?
    Mar 2006
    2001 FOXFIRE 0579
    no charge at auto zone, or napa, or similar.....just write down the code they read, then look it up here using the search
    Mar 2005
    01 Ebony - #0379
    Arrow
    Quote Originally Posted by IndianaVX
    Look here:
    http://www.vehicross.info/forums/sho...+ignition+coil
    Dec 2004
    I had it read this morning:
    401 EGR valve low flow
    Autozone price; $178.00 for a replacement ???
    Thanks for the help
  1. engine codes P0327, P0161
    By pbkid in forum VX Talk...
    Last Post: 04/20/2009, 07:24 PM
  2. engine codes?
    Last Post: 05/08/2007, 12:17 PM
  3. suggestions for engine P1404 and P0402 codes
    By bielsubob in forum VX Troubleshooting...
    Last Post: 01/03/2007, 01:20 PM
  4. Engine Codes?
    By colmhd in forum VX Troubleshooting...
    Last Post: 10/13/2005, 04:12 PM
  5. Check engine - Codes po171, po174, po303
    By Rapp in forum VX Troubleshooting...
    Last Post: 03/27/2005, 09:45 PM
