Results 1 to 5 of 5
Thread: Help!!!!!!!!!!
    Help!!!!!!!!!!
    FOLKS,
    I am about to treat my faithful Dragon to a new set of tires,I desperately need some advise.
    My precious VX still has the original set of tires,that was on the car when I purchased her off the showroom floor.
    Thank you....may you all have a lovely weekend.
    Regards,
    James
    Thanked: 7
    Post
    what would you like to know? You want to go to wider/taller tires? Check this thread for some info:
    http://www.vehicross.info/forums/sho...ght=size+tires
    Anita
    2000 Ebony #263
    AnitaProtich.com
    1999, Ebony, 0797
    All I can say is,
    Yokohama Geolandar HT/S G051 275/70/16
    A perfect tire for the stock rims. If you have the 1999 16" rims, that is.
    if you have the 18's, these won't fit!
    Thanked: 7
    He has a Dragon so its a 2000 or 01 with 18" rims
    99 Silver 0210
    James:
    The most important info you can post would be your wants, needs, and intended use.
    For instance:
    I like the stock sizing so my speedo stays accurate and I drive bunches of highway miles, so smooth and quiet is important.
    OR
    It's time to make the beast look huge, so I want some big, mean looking tires regardless of the ride and noise.
    OR
    I'll be driving on and off road, so I want a trustworthy all terrain tire.
    Cheers,
    Bim
