Page 3 of 16 FirstFirst 1 2 3 4 5 6 7 13 ... LastLast
Results 31 to 45 of 228
Thread: Permanent Fix for the plastic window tabs
  1. #31
    P.O. of 4 Vxs!
    Payment sent!!!
    Rowhard: it is the link under the customer gallery (same page, is the last link that says VX)
    Daniel
  2. #32
    Rowhard was drinking and was looking for my VX link under gallery's here....LOL
    Got your payment.......Thanks!
    Got four sets right now with the paint drying........will be sending yours out tomorrow.
    For everyone else you can order here
    www.streetboutiquecustoms.com
    Click on the VX link under MY customer gallery
    Tim
  3. #33
    1999, Ebony, 0797
    Done and DONE!
    Payment sent. It'll be nice to have working windows again, in time for summer!!!
    Thanks!
  4. #34
    2000 FIREFOX 0009
    I can't find it . Are they gone or I will paypal you tommorow.
    But I want a set.
    THANKS STEVE
  5. #35
    Dec 2003
    Former Owner 0216
    When you open up his site, the options are on the left side. You need to scroll down using the slider (not the correct term I am sure) next to the options and you will see it there.
    Payment sent and thanks for working these up.
  6. #36
    Dec 2004
    '99 VX Astral Silver #0949
    Quote Originally Posted by SBC
    When i made my first set i punched the mounting holes for Vertiacl Adjustments!!!! It didnt help the tilt problem at all..still tilts slightly!!!! Im working on a solution to the tilting but that will have nothing to do with the clips, the tilt has more to do with the play in the piece that connects to the cable !!! in my case anyways..............There will be holes for Horizontal Adjustments only.
    Tim
    Horizontal adjustment and "spacers" for the "play" is all the adjustments needed.
    I'm glad your addressing the horizontal problem.
  7. #37
    2000 FIREFOX 0009
    OK I still cant see where to pay. Under custmer gallery is nothing but VISA and PAYPAL logo's. How am I missing it?
    THANKS STEVE
  8. #38
    P.O. of 4 Vxs!
    Look to the link after/underneath the gallery..keep scrolling down (don't click on the gallery link, it's under that link...) The name of the link is VX...Hopefully you will find it this time.
  9. #39
    2000 IronMan #11
    My only window problem is that it tilts forward when rasing the window. Does this fix that problem. I didnt see a clear answer.
  10. #40
    The brackets should be a vast improvement on the tilting but I don't think it will cure all of your woes. Remember that you will still have glass sliding up a channel of rubber (under pressure). You will still need to perform regular lubrication or spread the channel to relieve the pressure. Hopefully I'll be able to swap out the passenger side rubber on mine with felt (I've already done the drivers side with great success) and take some pix next week.
    Any of you who snikered and had unclean thoughts when you read this - shame on you. I was trying to be technical but laughed when I proof read it.
    BTW, I'll be ordering a set too but I'm not in a rush for delivery.
  11. #41
    Quote Originally Posted by JHarris1385
    My only window problem is that it tilts forward when raising the window. Does this fix that problem. I didn't see a clear answer.
    I haven't found a cure for the Tilt (On Mine)by adjusting the brackets!!! The tilt in my glass is cause by to much play on the mounting bracket that is connected to the cable.......I made the Metal Clips to (replace) the plastic ones cause the plastic ones were braking! In Bulldoggies case adjusting the clips on his seemed to have cured his tilt problem...so i made horizontal notch's in the metal clips so you guys can play with the adjustments and there is enough metal to grind out if you would like to make vertical notch's as well.
    But like i said....adjusting the clips on mine did not cure the problem so when i get time i will look at the other part of the roller and come up with a fix.
    Tim
  12. #42
    Quote Originally Posted by RAZ
    THANKS STEVE
    You may need to clear your cache if you visited my site before the new link was up!!!!! or here is a direct link to the VX page by itself
    www.streetboutiquecustoms.com/vx.htm
  13. #43
    2001, Dragon Green, 1342
    No, I wasn't looking in this gallery but the one for the home page for Street Boutique Custom.
  14. #44
    2000 FIREFOX 0009
    Thanks that link worked payment sent!
    STEVE
  15. #45
    Got 8 sets made as of this evening......and 8 orders gonna be sent out tomorrow!!!!! Looks like no one is gonna be waiting on me to build these !!!
    Tim
  1. Outside plastic
    By Eagle Scout in forum General Tips...
    Last Post: 06/05/2014, 11:21 AM
  2. Finally : NEW PERMANENT WINDOW FIX !
    By maxw in forum VX Troubleshooting...
    Last Post: 06/14/2009, 08:50 PM
  3. My VX is now on permanent vacation
    By VehiX in forum VX Talk...
    Last Post: 10/22/2007, 06:58 AM
  4. get rid of scratches on plastic ?
    By jester0064 in forum VX Troubleshooting...
    Last Post: 03/11/2005, 06:59 AM
  5. Plastic fabrication
    Last Post: 05/01/2003, 07:17 AM
