Results 1 to 3 of 3
Thread: Tip on trans problem
    Jun 2007
    2001 IRONMAN #0685
    Arrow Tip on trans problem
    Slight vibration at highway speed, vehicle won't coast. Strange coast behavior, but trans upshifts normaly. The vibration of a cracked flexplate will take out the front pump. Begins as a minor & intermitant leak between trans and block that will eventually fill the little dust shield pan and leak over the front edge. This is the pump seal being egged out by the wobbling convertor. Next is the pump bushing, now even more wobbling of the convertor hub, egging out the bushing. When the o-ring for the input shaft to case is breached, she will lose the ability to coast. This means a front pump rebuild and a new flexplate. Cheapest fix for this problem short of finding a good used transmission.
    2001 Ebony 0177
    is?????? Haven't I been on this merry-go-round before?
    2001,FOX FIRE RED MICA,0251
    It's possible
  1. Trans. Filter
    By UNEVEN THOUGHTS in forum VX Troubleshooting...
    Last Post: 06/05/2017, 03:11 PM
  2. Trans is dying...
    By HeckaTrebeka in forum VX Troubleshooting...
    Last Post: 05/22/2013, 08:03 AM
  3. Trans problem
    By Cris in forum VX Troubleshooting...
    Last Post: 02/02/2011, 03:07 PM
  4. Driving problem fixed/TOD problem realized
    By mattlewis9333 in forum VX Troubleshooting...
    Last Post: 02/26/2010, 05:57 AM
