What size tire? I installed a wheel with the same spec using a 285/60/18 and had to trim the front cladding, pound the rear cladding (front tire) and crank the torsion bars up so that it sat level to get them to fit, but damn it looks good and was worth it. If you need more info, email me, will take some detailed photo's for you on what to do and where. You didn't say, is it 108mm center bore? Anything less will not fit.
Reason: addition
