Originally Posted by
etlsport
though.. ive noticed that really nobody with a s/c or extensive performance modding has blown an engine.. my guess is because they are often under the hood checking everything so the oil doesnt get a chance to get too low
My VX used oil when it was stock...after I installed SC and CAI w/cone filter and put aftermarket breather filter on valve cover and change PCV every other oil change it has stopped virtually altogether. I change oil every 3k miles and it is darn near full after 3k miles. At the most it might have used 1/4 quart but mostly it is practically full @ oil change time. I did clean my EGR @ 30k miles but now have 63k miles and haven't done it again yet.
I still do check the oil alot...usually in the driveway when I pop the hood to install the bra or at the gas station after a fill-up.
