Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 71 of 71
Thread: How "screwed" am I, literally.
  1. #61
    Thanks guys! I love a happy ending too. Whew. I was really worried about this for the last couple nights.
    Etl: The size of the plug is M14 1.5.
    Indiana: I have a few cameras, but for these shots I just used my little point and shoot Canon Powershot A620 with the macro (flower) enabled. I also have a decent lighting setup in my garage which helps, and I put the plugs on an old black leather glove for contrast.
    So, how worried about the tiny little metal shavings should I be? I mean, I pulled out that big nasty one, and a bunch of really tiny pieces on the magnet, and changed my filter, so hopefully I will be ok.... ???
    I just can't believe I did this. I must have started the plug in wrong last time I changed the oil and somehow didn't notice the resistance as I mashed it in there. I will say this though, I was in a hurry last time I changed the oil so in this case, I suppose haste once again made waste...
    Arrow
    Quote Originally Posted by nfpgasmask
    You're new friend, the magnetic drain plug, should be more than happy to earn it's keep.
  3. #63
    Thanks for the reassurance Dubster...
  4. #64
    Glad to hear the quick fix worked. Even more than a happy ending, I love when it's cheap & easy.
  5. #65
    Dec 2004
    Ah, high-five!!
    etlsport raised a good point - the magnetic plug won't pick up aluminum shavings, so if you are concerned about additional shavings in your oil (and you probably should be), change your oil & filter a couple more times in the next 1000 miles.
    tom4bren & psychos - so do you still disagree with me about the threads being important to sealing the drain plug? What happened to Bart was what I was getting at - if you've messed up your threads so the plug doesn't stop tightening, it can't hold the gasket tightly enough to form a seal.
    Yay!!! Mystery solved!!
  6. #66
    VehiGAZ,
    "...if you've messed up your threads so the plug doesn't stop tightening, it can't hold the gasket tightly enough to form a seal."
    I hate when I'm wrong (I thought I was once - but that was a mistake) ... glad I wasn't here. In your own words you verified what I said. The threads don't make the seal, they compress the gasket that makes the seal. By the very nature of how threads engage, they can not make a seal unless suplimented with something like teflon tape.
    Trust me, I've learned that lesson the hard way with MANY failed plumbing repairs.
    Besides - who (even Bart) could have messed up the threads that badly???? Oh yes, that was me when I was installing Tone's seat extenders (my fault not Tone's).
  7. #67
    LOL, I'm no mechanic, so it doesn't suprise me that I FUBARed something, but it all comes with experience I suppose.
    What I learned from this is that you should never work on your VX (or anything you care about for that matter) if you are feeling rushed or hasty. I'm sure had I not been pressed for time, I wouldn't have messed things up.....I hope.
    Quote Originally Posted by tom4bren
    Besides - who (even Bart) could have messed up the threads that badly???? Oh yes, that was me when I was installing Tone's seat extenders (my fault ot Tone's).
  8. #68
    "you should never work on your VX (or anything you care about for that matter) if you are feeling rushed or hasty"
    My problem is that I usually have about 6 things going at once.
  9. #69
    Yeah, me too. And this was definitely the case last weekend when I changed my oil. It just serves as a reminder that I need to take a breather, slow down, take a sip of my Blue Moon and do one thing at a time.
  10. #70
    Dec 2004
    Ain't that the truth! On the other hand, I have achieved glorious automotive feats while rushing... I once reseated a valve cover gasket on a hot engine in about 20 minutes, and changed all four sets of brake pads in 58 minutes (both on a 1979 Volvo).
    You're an amazing stripper by any measure, Bart!
  11. #71
    Red face
    I still don't know how I turned a bolt into a nail....
    Quote Originally Posted by VehiGAZ
  1. Replies: 35
  2. Pin Up Calendar...""site Donation"".
    Last Post: 01/01/2009, 12:06 PM
  3. Replies: 36
  4. "D" and "Low" Dash indicator jumble
    By Boogieman in forum VX Troubleshooting...
    Last Post: 09/28/2006, 10:07 AM
    Last Post: 02/02/2003, 02:12 PM
