Okay, before I pull the stock airbox and install the K&N cone filter to feed the voracious air appetite of the S/C, I want to know how many people have gotten the for high intake air temperature (fault code P0113 I think) after going to an OPEN high-flow K&N-style cone filter (one which does not draw air from the grill or fender). So please select from the following choices if you have installed a high-flow air open cone-type filter. Thanks!!
 Might want to remove restrictive elbow
