View Poll Results: Which of these has happened to you?
Voters
13. You may not vote on this poll
  • No high intake air temp codes/problems (have open cone filter and supercharger)
    6 46.15%
  • Had some high intake air temp codes/problems (have open cone filter and supercharger)
    1 7.69%
  • No high intake air temp codes/problems (have open cone filter only)
    5 38.46%
  • Had some high intake air temp codes/problems (have open cone filter only)
    1 7.69%
Results 1 to 8 of 8
Thread: High Intake Air Temp fault codes with high-flow cone filters
    Dec 2004
    Okay, before I pull the stock airbox and install the K&N cone filter to feed the voracious air appetite of the S/C, I want to know how many people have gotten the for high intake air temperature (fault code P0113 I think) after going to an OPEN high-flow K&N-style cone filter (one which does not draw air from the grill or fender). So please select from the following choices if you have installed a high-flow air open cone-type filter. Thanks!!
    2001, Dragon Green, 1342
    Well, glad to see I'm not the only one with this fault code. I have the MorganTec cold air induction system. Maybe together we can come up with a fix. I did try this weekend someone's suggestion about cleaning the MAP sensor in case it had some filter oil one it. Will have to wait and see if it is a fix or not.
    2001 Proton VX 0790
    Partial airbox made from $6 garbage can.
    This helps to not suck hot radiator air into the filter. Cold air= power. The difference on a blown VX is very noticable on hot days.
    John C.
    don't ya just love yankee ingenuity
    May 2007
    2000, Ebony Black, ....
    OK. Did ya ever wonder about the possibility of turning on the AC and plumbing the cold air into the ENGINE INTAKE!? Heh.. some laws of thermodynamics say that we'll waste energy, but some of it would end up in the mix and make for some very tourquey bottom end I should think. Might be fun to try... OR there's always water injection.
    I rermember this guy that brought his 93 turbo charged Chevy Cyclone PU out to the drags. He was icing down (with bags of ice) his intercooler between runs and getting faster each time! He won his class as I recall.
    COLD AIR GOOD FOR HP!!!
    Nice mod there Hotsauce.
    Thanks for all the help.
    Dec 2004
    Thanks for the responses & poll votes! (No need to stop though - this is good info!)
    I slapped on the Calmini a couple of days ago and only removed the top of the filter box and the filter. It does not look very pretty, but I haven't had any problems with it either. I will fab up something a little more permanent in the next couple of weekends that will suck at least a little air out of the wheel well.
    May 2003
    Wink Might want to remove restrictive elbow
    Thought this might be of interest to you:
    http://www.vehicross.info/forums/sho...t=remove+elbow
    Quote from the thread:
    "the elbow is between the fender and the air filter box.you need to remove the filter box to remove the elbow.i believe there are 2 bolts holding the filter box.then remove the S shaped piece that holds the elbow to the box.then remove the elbow and reinstall the filter box." shawn
    Dec 2004
    Thanks for that Shawn!
    I had found other posts alluding to the removal of the elbow but I didn't realize that's what they were talking about. I've decided to fab up some sort of straight intake tube to connect the throttle body & MAF (I'm still using a bendy tube) which will also allow me to extend the MAF & cone filter to that front corner of the engine bay. I'll pull the air box and the elbow when I do that, and that should lower my intake air temp even more.
    I also came across an old thread regarding "missing instructions" in the S/C kit for cutting a second hole in the bottom of the air box and attaching a short plastic tube to draw air in from behind the headlight. Seems pretty critical info to me, but these instructions only found their way to a couple of VXers - no one else knew anything about this!
    I have had no oil-on-the-MAF or high intake air temp problems since installing the cone intake, and I'm in the peak of summer heat right now, so that bodes well. The VX feels pretty quick (the Calmini filter definitely helps getting air into the S/C at high revs). I can't wait to drive it with air temps in the 60's!!!
    Now if I can just find a cat-back performance exhaust...
  1. High idling RPM's temp (temp) fix.
    By wwstone in forum General Tips...
    Last Post: 08/18/2010, 08:34 AM
  2. high flow catalytic converters
    By erland in forum VX Talk...
    Last Post: 05/03/2008, 04:55 PM
  3. High idle/ high power steering pressure?
    By Rene M in forum VX Troubleshooting...
    Last Post: 09/22/2007, 03:21 PM
  4. Air Intake Kit vs High Pwerformance Filter in Stock Air Box?
    Last Post: 06/28/2005, 09:11 PM
  5. Fault Codes?
    Last Post: 02/12/2005, 07:42 AM
