Results 1 to 15 of 27
Thread: Switching Front Seats
    2000, Ebony, VX, 0370
    Thanked: 12
    I think one or two people may have done this already, or had the dealership do it, but it doesn't seem like it would be too hard. My seats are in good shape, but I would like to switch them from side to side before my drivers side seat gets too worn. I took the passenger seat out a few weeks ago, and it looks like switching the slide rails would be easy to do. The only problem I see is the passenger side release that allows it to slide forward for access to the rear seat. I know the slide is taken care of by the rails, but I can't figure out how, or where, the cable that runs up into the back of the seat connects. Has anyone done the switch themselves? Advice? Instructions?
    Lightbulb
    Maybe just switch em' & access the rear seat from the drivers side?
    2001, Proton Yellow, #0580
    Steering wheel keeps the seat from folding completely foreward - limiting access to the rear.
    -- John
    2001,FOX FIRE RED MICA,0251
    who needs back seats anyway lol i took mine out so i would have a place for the subs.
    2001,Ebony,VehiCROSS,1092
    Just bought a VX New Beetle to save gas on my commute - somebody needs to figure out how to use the seat tracks from those in a VX! The seat bottom lifts and the whole seat folds forward - GREATLY increasing the ability to get into the back seat. I also saw this on a 2dr BMW. Getting into the back seat of the VX is an acrobatic endeavor when you're 6'1" and 220#! Actually, it's the getting out that is the worst!
    2000 IronMan #11
    Seat rail extenders? If you dont have them, get them.
    Looked into that option - but I don't care for the higher position of the seat, and less travel fore and aft.
    Sep 2004
    1999, Astral Silver, VX, 0938
    How about leaving the tracks where they are and switching the seats only ( of course remove all to switch) Left seat on right track, Right seat on left track...
    the seat tracks are the same from what i can tell.. but there is a cable attached to the passenger seat fold lever that releases the sliding mechanism at the same time.. the problem is finding where that cable attaches to the seat... i looked in the seat disassembly instructions of the vx repair manual... it doesnt show where it attaches though
    Feb 2004
    1999, Silver, #1349, "SOLD"
    I've swapped mine twice. If I recall correctly, the seat mount rails are NOT the same. The seat has to be swapped to the opposite rail.
    The "auto slide" mechanism is in the seat itself so you lose the feature when you swap seats. It will still slide forward and the seat back operates properly, just not "automatically".
    2001, Dragon Green, 1342
    Quote Originally Posted by marcosv6
    So bottom line, how involved is swapping the rails?
    Feb 2004
    Not hard, just takes some time. Remove both seats, including tracks. Flip upside down, remove 4 bolts/seat and swap over. I believe the bolts are 1/2" but it takes some movement of the tracks forward and back to be able to remove the bolts. I didn't notice any height difference.
    One odd observation: the passenger seat wears much faster than the drivers seat with everyday use. Coincidence ?
    Don
    Don
    maybe the passenger seat is used less.. so the leather hardens a bit and is more prone to cracking? since the drivers seat is used often the leather stays supple and doesnt crack as easily... be sure to condition the leather often to keep it from cracking!
    Sep 2004
    Don
    Don: If your not the original owner maybe they were switched before..food for thought
    "Looked into that option - but I don't care for the higher position of the seat, and less travel fore and aft."
    Raque,
    I put in the Tone's seat extenders and love them. I didn't notice any appreciable height difference even though I know it's there. Maybe I'm just less sensitive than others to it though because I've heard others with that complaint. I think the extenders only put the seat about 1/2 inch higher.
    The seat extenders won't affect seat travel fore and aft. The extenders just move the whole mechanism several inches forward so the travel remains the same. The only thing you lose is how far back you can adjust the seat and that hasn't been an issue for us.
  1. Replacement Front seats
    By Bieredalsace in forum VX Modifications...
    Last Post: 08/07/2014, 08:11 AM
  2. Switching seats
    By garygrist in forum VX Talk...
    Last Post: 02/25/2014, 07:43 AM
  3. Front seats swap?
    By Boogieman in forum VX Modifications...
    Last Post: 08/16/2006, 01:46 PM
  4. Lowering Front seats...?????
    Last Post: 03/20/2005, 12:09 PM
  5. Swap front seats?
    By Randy in forum VX Talk...
    Last Post: 06/30/2004, 03:58 PM
