Results 1 to 4 of 4
Thread: Garage Door Controller
    Oct 2006
    2000, Green, Vehicross, 0054
    Does anyone know if the factory garage door kit for the key fob "option" button works with rolling codes on the garage door. I don't know if I'm using the correct wording on that, but I know I had a devil of a time coding our homelink to our garage door. I know it's not something simply like 1 channel or two, I believe it is a rolling code.
    Any input would be appreciated.
    Jan 2006
    Rolling code would be the correct terminology.
    I found this thread.
    From what I understand on what he is saying, you have the reciever that accepts the signal from your "options" button, which in turn opens the garage door using "hard wires" to the garage door switch.
    I remember talking about this at one point. We had thought it accepts the signal from the key fob and then in turn sends a signal to your opener. I guess I was wrong back then.
    2001, Proton Yellow, #0580
    From what I remember the button controls a module that fits in-line with the internal "open/close" button - it's bascially a remote control relay that's switched by the button on the remote. There's one currently on eBay:
    http://cgi.ebay.com/ebaymotors/ws/eB...m=110173185912
    Edit: Just realized I basically repeated what Knigh7 wrote above
    -- John
    Oct 2006
    unfortunately, the one on Ebay (and the entire reason for my question) is no longer available,
    thanks for the responses, I'll know better next time one shows, if and when that happens...
  1. Replies: 12
    Last Post: 12/25/2012, 08:43 PM
  2. I just opened my garage door again
    By JMNY in forum VX Talk...
    Last Post: 08/24/2012, 07:11 PM
  3. Isuzu Garage Door Opener Link
    Last Post: 10/23/2009, 10:41 PM
  4. AC controller display
    By gunpackingpoet in forum VX Troubleshooting...
    Last Post: 04/17/2007, 07:53 PM
  5. I installed Isuzu Garage Door Opener
    By IsuZOOM in forum VX Modifications...
    Last Post: 07/27/2003, 01:33 PM
