Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: rear door knobs
  1. #16
    Sep 2007
    Well i saw the rough proto type's today and i love them...
    no longer hollow and look real nice but i only got to try them out then they ran off with them.
  2. #17
    99,silver,vx,1685
    Quote Originally Posted by Rene M View Post
    any word on the price?
    My cow died last night ......so I don't need your bull!
  3. #18
    99,silver,vx,1685
    bump
  4. #19
    I just ordered 5 of them from Merlin for about $4 each I think. I didn't even think about the color....
    I guess I will have to see what comes in the mail. The dowel idea is a good one.
    Also, I have been thinking about an alternative to these made from large thumb screws with rubber ends (I'd have to post a photo). Basically, just tack weld a few bolts of the appropriate size to that metal bracket that houses the female part of the screw, and then use an appropriate thumbscrew to match. The only tricky part would be finding a piece to hold the screws in there once they are loosened....
    1999. Unique Ironman
    bump
  6. #21
    I hear ya cluckin' Red Rooster...
    I've had an alternative to the stock "E-Z breaks" in the works for months, but it's become kind of a back burner project.
    I found some rather large cap screws, & by large I mean the heads on these things are nearly as large as the stock e-z breaks.
    Anyway, rather than tack weld anything, I epoxied the proper size nuts to washers that I'm going to pop rivet in place on the bacl side of the female part of the stock location.
    Is this making any sense ???
    Just throwin it out there as an E-Z alternative to welding. (not that there's anything wrong with that)
    Excuse me, that Sienfeld reference didn't go unnoticed, did it ?
    I'll try to post some pics tomorrow.
  7. #22
    Apr 2003
    I had no problems with broken knobs. but one of the plastic sockets that the knob mounts to inside the door .. a tab broke off of that...
    Thoughts aside from epoxy to mount it in place?
  8. #23
    Yeah, basically the same idea, except I figured a weld would hold better in the long run, whereas epoxy may eventually break. By this summer I should have a nice garage and a welding setup so I might just do this. The only drawback is the cap screws will come free when you remove the trim piece. But, I would rather have something heavy duty.
    PS - Having a welding setup will probably result in a lot of things...
  9. #24
    1999, Ebony, 0797
    Anybody ever get these made, delivered and installed?
  10. #25
    Eric, do you still need one? I do have one red on left, but I painted it black. You could probably strip the black paint off with some thinner or acetone. If you want it, let me know.
    1999, Ebony, 0797
    Hi Bart!
    Thanks, but I already ordered some extras from Merlin. Hopefully I'll get the red ones, since there seems to be some confusion regarding the actual part numbers...
  1. Rear door knobs?
    By ScottinMA in forum VX Talk...
    Last Post: 04/15/2015, 05:17 PM
  2. ebony rear door
    Last Post: 10/22/2014, 03:53 PM
  3. New rear door
    Last Post: 08/06/2012, 04:47 AM
  4. Wood Dowels in plastic knobs on back door
    Last Post: 02/23/2011, 09:07 PM
  5. Rear door knobs
    Last Post: 02/27/2008, 10:49 AM
