Results 1 to 12 of 12
Thread: keyless remote battery
    Mar 2004
    2001, Kaiser
    Anyone know how long the keyless remote batteries last? The original batteries on my 01 are still working; though I was wondering if replacing the old batteries would increase the (very limited) range? Does anyone know the replacement battery size?
    Thanks.
    1999, Ebony Black, VX ,1976
    CR2025 is the correct battery. shawn
    1COOLVX
    Quote Originally Posted by UtahVXer View Post
    Thanks.
    One thing that will increase the range is to move the antenna wire from the door threshold to the drivers side A pillar. Do a forums search for "wireless remote" for more detailed instructions.
    There is also info. available on a replacement battery that is a little thicker (but still fits inside the fob) & has a ittle more "juice".
    originally posted by "spacetruck'n".
    The original battery is a CR-2025 and still says its got three volts. Never being satisfyed, I looked around for something with a bit more balls. (That's an industry term) Thinking of where I last saw a battery such as that. I remembered the one in my dogs flashing LED collar. It uses a #2032 lithuim watch battery for "up to 250 hours of blinking visability" I found it to be about one tenth of an inch thicker but still fit, and the extra gram or so of "whatever" should make it last a bit longer than the stock anorexic coin cell.
    Sep 2004
    1999, Astral Silver, VX, 0938
    After getting tired of the weak distance of our unlock/lock I remember reading a couple post here about installing two CR-2025 batteries and relocating the receiver wire from the lower threshold position up to the windshield pillar position. I've had this mod for over 3 years and it did help some but still below average on distance
    2001 Ebony 0177
    Point the fob at the under side of your chin when you push the button. Looks kinda weird, but it will give you maybe 10 extra feet of range. Don't know why it works, but it does.
    Dec 2004
    '99 VX Astral Silver #0949
    the range of the fob has never bothered me, but the life of the batteries is way too short. I've even switched to the lithium battery. I seem to only get a few weeks before they are dead.
    The only reason I can come up with is coins in my pocket holding the button down?? or just the button is not recessed enough to be in pants pockets?
    I don't even bother with it anymore, don't want to set it off if the fob is too weak to dis-arm the alarm.
    2001 Ebony 0177
    Something's up....I've O.E.M. 2001s in both of mine.
    Dec 2004
    Quote Originally Posted by Chopper View Post
    BTW this trick does work!
    If you are still using 6 year old batteries, I sure I need a new fob.
    Mar 2004
    2001, Kaiser
    Two Batteries???
    Quote Originally Posted by VCrossfan View Post
    After getting tired of the weak distance of our unlock/lock I remember reading a couple post here about installing two CR-2025 batteries ...
    Has anyone actually done this? Used two batteries instead of one? That would double the voltage which could damage the transmitter; but if others have done it successfully, I would like to know, so I can safely do it myself. The extra voltage might boost the power output of the transmitter and the range. But I have learned to be careful about changing voltages on electronic devices.
    Thanks again.
    Sep 2004
    Thanks again.
    I've done the 2 battery (see post #5) and I relocated the reciever wire,,seemed to help a slight bit. And on the other post about holding the pocket unit under your chin, it seemed to work better at times..lol
    guess i am one of the lucky ones.. i re-routed my antenna wire and use the 2025... just a few minutes ago my remote worked fine from the front door to my vx on the other side of the street.. (50-55 feet) i always just make sure to point the fob at the vx like a remote (i know it shouldnt matter since it is an RF signal.. but still do it and it seems to help)
  1. Need a remote for keyless entry??????
    By Dino in forum VX Troubleshooting...
    Last Post: 06/17/2007, 07:33 PM
  2. Keyless Remote
    By CrnCnn in forum General Tips...
    Last Post: 01/25/2007, 09:28 PM
  3. Keyless Remote Range
    By PorkChopXpress in forum VX Talk...
    Last Post: 04/26/2005, 05:55 AM
  4. Keyless Remote Programming
    By RobVX in forum VX Troubleshooting...
    Last Post: 06/02/2004, 10:37 PM
  5. Keyless Remote
    By I_Wanna_Retire in forum VX Talk...
    Last Post: 07/17/2003, 10:35 AM
