Rear Axle Abs Speed Sensor
I had my rear axle bearing go out, which in turn dropped the axle enough to destroy my driver side rear ABS speed sensor (ring with fins and actual sensor).
My question is what year Trooper axles would have the same ABS speed sensor there? is it 99-02? 98?
The reason is I can buy entire 12 bolt axles for cheaper than Isuzu wants for a speed sensor.
I know the info is here somewhere but my searching skills suck I guess
