Results 1 to 15 of 22
Thread: Interceptor Questions / Problems
    Ok... well... I finally got that sumbeech installed.
    When people say it's a tight fit, that's a load of crap. It's a f'in' impossible fit for someone of my size. Ugg... I think I might have permanantly damaged a nerve trying to get the interceptor installed.
    Anyway...
    My question is this; on the instructions, it says to install the red wire onto the main wiring harness... on the red wire with a silver stripe (as per Tones directions) -- but I don't have a red wire with silver stripe.
    So I broke out the multi meter and measured line voltage on each pin. Well, in the process, I popped my check engine light. Anyway, while looking at it, I came across 5, 10 and 12 volt pins on the three pilons.
    Which wire should I be hooking this to? Can someone give me a a pilon and pin number? Or a wire that actually exists by color code? Barring that, what sort of voltage does the interceptor require? 5, 10 or 12 volts?
    Yes, my problem also! Baxman gave me his old Interceptor to try which I installed this weekend. I didn't know what to do with the red wire. The Interceptor didn't really have much with it in terms of official instructions. I don't remember reading anything about the red wire, so I just left it disconnected. The VX works fine, but I don't think the Interceptor is doing anything right now.
    Grant
    Grant
    2000 Proton Yellow #756
    "THE UFO"
    Seattle, Washington
    One other thing... some people were talking about hooking it up to a switch to turn it on and off.
    Why would you want to do that? What's the advantage to turning it on and off. I was under the impression this is something you'd want on all the time. I've also read the settings for the pressure and delay should be 100% and 40-50% ...
    Is it just individual preference, or is there actually a "best" setting for the VX? What should I be looking for in shifting etc... with the interceptor installed vs w/o it?
    I don't know why you would turn it on or off either. If a dealer is going to see it down there, and they are the type of dealer that HATES MODS, then it doesn't matter whether it is on or off while still in place... it's STILL THERE.
    By the way, I ran the red wire up to the fuse box in the engine compartment and plugged the wire into the fule pump fuse.
    The red wire in the black connector (shown in the instructions) has both silver (or white) and green markings on it and provides switched 12v. Any 12v switched power wire under the hood will work. This is required for the torque converter delay portion of the Interceptor.
    Line pressure is adjusted by the other pot and it does not require any power to work so it will function with out the red wire connected. Adjust line pressure to our liking but on 00/01, you probably don’t want to exceed about 20-30% increase. 99s have lower pressure to begin with and can see more increase. Delay is best left at maximum so you carry more power through the shift before the converter locks up.
    I just installed one on a buddies ‘00 yesterday. The interceptor comes with it’s own set of instructions as well as the one I create that is VX specific. If you continue to have difficulty, please let me know. I will post the install instructions on my site.
    Hi Tone,
    My black connector didn't have any wire like you described. I installed it on the Black with Yellow stripe wire and it's working.
    However, now that it's active, when it shifts, it clunks and is a real rough shift on the upshift (not as bad) and especially on the downshift. What should I do to smooth that out?
    The interceptor that I have is from RoninX, and it looks like it came from you Tone, so I have those directions, but they aren't much help for me (being a complete vehicle mechanic novice). It took me an hour and a half to find the right place to plug this thing in. I think the biggest help/change to the documentation is some more detailed pictures (perhaps from farther away, so you get perspective) of where you are suppose to find the plug, as well as the best angle of attack to get that plug. Maybe putting the VX up on a rack and taking some pics of exactly where the plug is from a distance would be a big help.
    I finally settled on doing it totally by touch to avoid awkward positions in my hands (I pinched a nerve in my wrist doing this, arrg) and it went in much easier than trying to do it while I could see it as well.
    The pic of the wiring harness that came with it was in black and white and squished from it's original size, so it wasn't much help.
    So now if I can dial this thing in so it's not so rough, I'll be in good shape
    Feb 2003
    Lightbulb Interceptor????????
    I picked up one from Tone while in Moab. It came with the same direction you all probably got. Yes, it doesn't say much, cause there isn't much to say. It explains all that needs be.
    Only problem you should have is finding the correct plug to connect it to. Then route your power cable up through your engine bay(as others have done) and hook it into the fuse box to your fuel pump. Now just follow the instructions that say put adjustment for pressure lines to half way and adjust from there....if you don't have a pressure guage. Next, do the same with torque convertor delay.......then adjust from there.
    Doesn't take long at all....unless you have a diamond plate skid plate, then it is better to remove it, but not necessary unless you have big hands like mine, then it was totally necessary.
    I didn't have a problem with getting it connected, no pinched nerves, etc... just finesse it.....or find some neighborhood kid running around and pay em to do it for ya;Dp; .
    A few adjustments was all it took for me to get it where I liked it. I mounted mine to the frame in such a fashion as to where it would be easy for me to turn it to the side, adjust, then turn it back against the frame. If you do this make sure you have cables lifted away from exhaust or they will sag and get scorched.
    Now, that I have mine adjusted where I want, I can remove it from the frame and mount it permently up and away from frame and exhaust, so as not to ever worry about it being exposed or scorched by exhaust.
    Originally posted by Tone
    Line pressure is adjusted by the other pot and it does not require any power to work so it will function with out the red wire connected. Adjust line pressure to our liking but on 00/01, you probably don?t want to exceed about 20-30% increase. 99s have lower pressure to begin with and can see more increase.
    I have my line pressure set to MAX for now. Will that damage the vehicle?
    Feb 2003
    lINE PRESSURE....
    you probably don't need the line pressure set to max.....I don't think that's good.....I only have mine like a little less or more than half way............You should probably seriously back off that adjustment.....
    2000 Dragon Green VX 0485
    After reviewing the Supercharger Warranty Thread. I wonder if the Installation of the interceptor would void the Xmission warranty? I suppose if there were transmission problems you could (make that should) remove the interceptor kit before visiting your "The wonderful world of Isuzu Dealership"
    ANY mod could of course cause that - I certainly would advise removing anything that the dealer could gripe about. I have run the interceptor for over 3 yrs with no problems and my dealer / mechanic have seen it. The company that makes them is very well respected in the transmission industry and the Interceptor if used at less than 100% boost can actually extend the life of the tranny.
    I have line pressure set to about 25% and delay at max. It cleared up most of the "clunk." But I still have a clunk when it downshifts into 1st gear... what should I do about that? Decrease the pressure more?
    Once I get it set... where should I mount this thing? I currently have it zip tied up onto the body by that hook that's near the tranny. The pots are facing down, with the rubber stoppers in them. Should I move the whole unit, flip it over (so the pots are against the body of the car, or possibly encase it in a plastic bag?
    There is the potential, however slight, that it could become submerged at some brief points in my adventures, could this cause a problem?
    Re: Interceptor Questions / Problems
    I popped my check engine light, too. How do you get it to go off? Is yours still on? I tried resetting the computer by disconnecting the negative cable and turning the started to ON for 30 seconds, but that didn't work. Maybe I need to leave it disconnected for 20-30 minutes to fully drain it.
    Feb 2003
    Check engine light?
    You got it, 30 minutes or more does the trick
    Mine shut off on it's own after a few starts. If all else fails, go to Autozone, most of them have a computer that can reset it (and tell you what it is)
  1. VX Interceptor
    By handeeman in forum VX Talk...
    Last Post: 06/20/2009, 02:44 PM
  2. Trans. Interceptor
    Last Post: 06/21/2008, 07:33 PM
  3. Autotrans Interceptor
    By MachineVX in forum VX Modifications...
    Last Post: 09/07/2004, 05:47 PM
  4. interceptor help
    By technocoy in forum VX Modifications...
    Last Post: 09/05/2003, 01:29 PM
  5. Interceptor Adjusted
    By Hotsauce in forum VX Modifications...
    Last Post: 06/21/2002, 10:36 PM
