OME springs. I have not measured yet but i swear it looks like my springs are sagging. I now have a slight nose up in the air look to the VX. Nothing major, i just am very particular about my VX as you could imagine.
Anyone else have this issue?
Replace with springs from an FZJ80???
you check the shocks?
IMHO
I wouldn't suspect the shocks since they just dampen the spring action (even pressurized shocks wouldn't affect ride height).
It's also doubtful that both springs would sag the same amount. If the VX sits level when on level ground then I don't thing the springs are sagging.
Try to get some measurements - frame to ground, frame to axle - to check against another stock ride.
I doubt shocks, I pretty much lifted my torsions to equal an almost level vx with a very slight drop in the front. Now that it looks like the rear is slightly dipped i assume something is wrong with those 912's. Just curious if I was the first to have this issure or if someone could come up with anything else. I will have to break out the meter stick and measure soon...
anyone, anyone???
