Well..It's coming down to the wire...
Got the brake system flushed & filled with synthetic brake fluid, changed oil & filter, fuel filter, pcv valve, greased everything on the bottom side, converted the roof lights to HID, and wired in a blue "neon rope light" around the overhead console...
Won't be getting the rear locker in, as I'm a little gunshy about trying to remove the(e-z break) rear sensors this close to departure time.
Still might (if I have the time), pack front wheel bearings, clean IAC & EGR.
The closer it gets, the more I feel like I'm forgetting something...as usual.
