Results 1 to 9 of 9
Thread: Ball Joint Flips
    Nov 2002
    01 FireFox VehCROSS 0459
    Ball Joint Flips
    Are there any pictures of this ball joint flip and what does it do?
    Whos who in the Zoo
    Feb 2003
    ball joint flip????
    You just unbolt them and bring them down......basically instead of over they are under. Can take pic tomorrow night, but someone will probably posta pic before me
    '99 Astral #1977
    RichD
    2000 Dragon Green VX 0485
    When you crank the torsion bars you lose some downward travel. Flipping the ball joints aid in regaining a portion of that travel. I recommend this kit for further increase in down travel
    http://www.independent4x.com/item.html;$sessionid$W3SEBJYAAAKPVTZENUGETIWPERWRJPX0?UCIDs= 839915%7C1109486&PRID=1163612
    '99 Ebony VX #0038
    The article that AnalogVX posted mentioned that flipping the ball joints corrects some of the alignment issues with cranking the torsion bars. How will installing the spacer kit affect alignment? Aside from the alignment issue, how will these mods affect on-road driving?
    Also, from the pictures in the Planet Isuzoo article, it looked like the flipped ball joints wouldn't be nearly as well supported by the upper control arm - has anyone had any problems with this? Does the spacer also help give it some added strength?
    Ball joint flip with spacers may affect your camber. I had to buy longer bolts to accomodate the increase in shims to align.
    Ball joint flip even when hard wheeling appears to have no detremental effects on strength at the A arm. Cannot say that strength is increased or decreased with install of spacer, just have had no problems.
    Nov 2002
    When you're dealing with suspension it's a three-dimensional deal. As mentioned in the article, the ball-joint flip is primarily to maintain proper alignment after a lift. The added benefit is increased down-travel on the suspension. The purpose of a spacer is to maintain the alignment if the amount of lift exceeds the adjustment made by flipping the ball-joint. As long as you maintain proper alignment your handling won't be affected other than the normal results of increasing your center-of-gravity.
    '99 Ebony VX #0038
    I have my torsion bars cranked nearly all the way up, but I never had my alignment checked or adjusted. Does this mean that it's definitely off, and that I should seriously consider flipping the ball joints? Do I have any way of knowing if the spacers will be necessary before having it realigned?
    Feb 2003
    Thumbs up bj flip..........
    I have had no problems with flipping my ball joints. Only concern would be that it exposes and I took on a good nick on one of my tie rods. So, you might want to get re-inforced tie rods.....I am inpro on some now....
  1. Ball Joint Flip - Did you do it? Why? Why Not?
    Last Post: 02/05/2016, 09:07 PM
  2. Ebay ball joint kit
    Last Post: 01/29/2015, 02:08 PM
  3. Ball Joint Replacement
    Last Post: 10/28/2014, 11:59 AM
  4. Replies: 6
    Last Post: 07/18/2014, 09:39 PM
  5. Ball Joint?
    By V12BMW in forum VX Talk...
    Last Post: 11/13/2004, 09:42 AM
