Results 1 to 13 of 13
Thread: Door Lock Engaging while Driving
    2001, Proton Yellow, #0580
    This is an odd one - and it just started happening a couple of weeks before Christmas. When I slow down for a stop sign, my door locks activate (it doesn't happen all the time, just some times when I come to a hard stop). It's really odd, at first I thought it was the side of my pant leg brushing the locking button. Think a bad relay?
    -- John
    NC 1999, ironman, 0358
    You could swap relays and see if the problem moves (or disappears). A good description of the VX I read a while ago was that they are "quirky". it seems we get some intermittant problems that just disappear on their own; e.g. rattles, check engine lights, etc.
    Is it a good idea to disconnect your battery every once in a while (yearly maybe) to reset the computer and clear things?
    Western North Carolina...
    Veni, Vidi, Velcro
    Nov 2002
    If the return spring in the relay is weak and the relay is oriented in such a way that the contact paddle is moving due to decelleration then it could be the case, especially if it only happens during hard stops. Don's suggestion of exhanging the relay would be a good test, and could be entertaining depending what function you exchange the suspect unit with. :bgwg:
    This is an aftermarket safety issue!!
    I wonder if this could be related to the auto-relock feature that relocks the doors after about 15-20 seconds if you don't open a door. I've unlocked my doors with the remote and then opened the rear door to put packages away, and then had the doors relock before I could open the driver's door. I don't know if this feature can be disabled, but there could be some sensor or program in the computer getting bad info and engaging the locks. I wouldn't know how to troubleshoot this problem either. Reboot?
    Gregg
    2001 Proton Yellow #1379
    Jun 2007
    2001, Proton
    Door locks
    Not to hi Jack but I have to say the way Isuzu programmed the door locks to work I would not be surprised if this is an allowable program that you accidently engaged. I often wonder what they were thinking when they made these decisions.
    Jan 2008
    1999 Astral Silver 0481
    Doors
    I trully believe that somehow i've engage the power doors automatic systems.
    2001 Foxfire 1232
    Quote Originally Posted by Cobrajet View Post
    I I don't know if this feature can be disabled, but there could be some sensor or program in the computer getting bad info and engaging the locks. I wouldn't know how to troubleshoot this problem either. Reboot?
    Per page 7 of the "Keyless Vehicle Security System" manual: "This feature can not be defeated"
    That would certainly be something, considering the VX doesn't have any automatic lock activation other than the one mentioned above.
    I thought I was having the same problem for a while. It ended up that Wifey has a lifelong habit of always locking the doors & it was her all along. She grew up in Philly so I am understanding.
    yea.. my doors are always locked!
    My relock feature is a pain... recently it only sometimes recognizes that the passenger door is open for some reason.. (dome light still comes on) but the relock will engage.. and if my tailgate or passenger door is still open.. all heck breaks loose because the air horn starts blaring
    Johnny did you ever figure this out? i know a lot of aftermarket alarms have an autolock feature that activates at a certain speed .. is yours totally stock?
    I'm pretty sure there's a short in my aftermarket alarm somewhere - when it happens I get the alarm chirp - but the alarm doesn't engage (blue light doesn't come on so it's not armed). It's pretty weird - hasn't happened for a week or so, then it'll happen for a couple of days. Then stop again. I hear a couple of rattles under the dash so it may be something has come loose - the aftermarket alarm module is in the same spot once occupied by the Isuzu module (behind the dash) - I'm guessing it may have been an extra relay that was added, now loose, bumping up against something. I've been meaning to crawl around under there but I've been extremely busy on the weekends, and get home after dark during the week, so I've been lazier than usual in regards to the VX. Excuses, excuses!
    -- John
    Oct 2007
    2001, foxfire red #1096
    is there anyway that we could change from just unlocking and locking them ourselves to when we start the car the locks would lock and then everytime you change to parking they would unlock like in nice new cars?
    Albert Einstein
    Nov 2007
    1997 SILVER
    Quote Originally Posted by Pepino View Post
    That's exactly what my after market alarm does.
    You have the option -
    Want doors locked while driving - shut both doors and then start engine - doors lock - stop engine - both doors unlock.
    Want doors unlocked while driving - leave one door open - start engine - shut door - doors stay unlocked.
    Alarm also has 2 function immobiliser - cuts ignition and fuel system.
    Gives remote entry from about 100 yds away.
    Can be rigged for remote start if you want, but it doesn't get that cold down here.
    I think the brand name was Black Spider - will have to check to make sure, but it is Aussie built so no help for most of you.
    Regards
    PK
  1. Stuck Door Lock!
    By RAZ in forum VX Troubleshooting...
    Last Post: 05/30/2015, 10:22 AM
  2. Door Lock Rod Clip - help finding replacement
    By davidrepas in forum VX Troubleshooting...
    Last Post: 01/01/2012, 05:59 PM
  3. HELP - Door Lock Issue
    By mikieg in forum VX Troubleshooting...
    Last Post: 03/26/2011, 09:19 PM
  4. door lock motor
    By protonvxmatt in forum VX Troubleshooting...
    Last Post: 04/01/2009, 09:16 PM
  5. Door lock internal mechanism
    Last Post: 07/10/2008, 02:24 PM
