Results 1 to 6 of 6
Thread: A little help? (Wheel question)
    2001 Ebony #0211
    Hey guys,
    I'm sure you're all tired of aftermarket wheel questions, and I hoped to solve it on my own, but I'm lost. I need new wheels. I know the OEM specs for the stock 18's I have now. The new wheels I'm looking at are ProComp US Stryker Series 7 Forged, 18x9, bolt pattern 6x5.5, 0mm offset, with a 5" backspace. Can anyone tell me if they'll fit? I believe they will, but the whole backspace / offset thing has me confused, although I've read dozens of strings in the forums about it. Also, the tires I have currently are practically new, and I'd like to keep them if I can. They are 265/60R18's. According to the manufacturer, they are good for rims up to 9.5" wide, which should be fine. I guess I'm just looking for one of you knowledgable people here to confirm that everything will work.
    2000 IronMan #11
    Assuming the bore is big enough and this is not a GM made wheel then you are fine. I have pro comps on of similar bs and offset only in 16''.
    2001, Dragon Green, 1342
    Well, no real pro, but might be able to help some. First off, you need a wheel that has a 108mm center bore, you didn't say if that wheel does. As far as offset, the OEM is a 38mm positive, so you are going to be shifting the wheel and tire out 38mm, (1.496 inches) now, since your using the standard size tires, that should work, maybe a slight trim of the cladding. But down the road if you want to go bigger, then that might be a problem. See if who ever is selling will do a trial fit and do it with weight on the wheel and turn it full lock. Hope that helps a little.
    2001 Ebony #0211
    Thanks guys...I'm having a little trouble getting the center bore measurement. I know I need 108mm though. Hopefully someone there can answer that for me. You're the best.
    make it easy for them, 108mm equals 4 1/4 inches
    2001 Ebony #0211
    I'll do that...thanks.
  1. factory wheel question
    Last Post: 03/09/2010, 12:51 PM
  2. Another wheel and tyre question...
    Last Post: 06/11/2009, 01:30 PM
  3. general wheel question
    Last Post: 06/25/2008, 05:52 PM
  4. another wheel question
    By dmfk in forum VX Modifications...
    Last Post: 08/06/2007, 07:31 PM
  5. wheel fitment question
    Last Post: 04/16/2004, 01:16 AM
