Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Thread: Torque binding when turning a sharp corner
    Our Vehicross is experiencing what I'm told is torque binding when turning a sharp corner. Can someone please explain this and how to fix it?
    What are the symptoms - tire chirp, bouncing, ... ?
    It feels like the transmission is in super-low and the tire is rubbing on something (which it is not). After the car is straightened out, it's fine.
    2001, Proton Yellow, #0580
    Could be a few things - I experienced something similar when the TOD speed sensors went out on mine (the FWD was bascially disabled so it was pulling load during turns instead of driving the front wheels). What you're describing could also be bad CV joint(s) from my past experience with Hondas.
    -- John
    The wheel bearing are going bad too. Could bad wheel bearings lead to bad CV joints?
    Nov 2002
    Lightbulb
    It's common for short-wheelbase vehicles to do this, and with only 90" the VX is firmly in that category. My Trooper RS did the same thing.
    If you've got worn out steering/suspension components the added stress will make it more apparent.
    1999, Ebony Black, 1856
    Mine has done this since 5k miles (when purchaced)
    I wouldn't say that bad bearings leads to CV joint wear. The bad bearings could certainly give you the symptoms you describe.
    Bad CVs usually show up as a noise issue long before it gets bad enough to 'feel'. Clicking during coasting usually means the inner CVs are bad. Clicking during turning usually means the outer CVs are bad. Have you checked your CV boots? If you're not lifted & your boots aren't cracked or split & you don't hear any clicking noises (changing with speed) then your CVs probably aren't bad.
    Maybe try to adjust the steering lockout bolt so you can't turn as sharp? No idea otherwise.
    Jan 2007
    *BHC* 1999 Ironman. :D 0454
    Is your tTOD check light on?
    Cuz if it it, then your rear and front speed sensors that are located on the TOD itself have gone bad, or dirty connectors, or broken wire, pretty much what JohnnyAPollo said. But if not, then I don't know.
    Turning My VX Into Rally VX
    2001 Proton VX #0690
    Quote Originally Posted by mrlegoman View Post
    I wonder if you're seeing what I described as "Chirping"? When I asked about it, I was told it was pretty much normal. http://www.vehicross.info/forums/showthread.php?t=12036
    how fast are you doing when you get this? every so often my ABS used to (when i still had ABS) kick on when i would make a wheels locked turn and touch the brakes at all the whole car would shudder until i released the brakes
    Quote Originally Posted by CoastieCosta567 View Post
    After the post the other day, I was driving home and the TOD "CHECK" light began flashing at me. The display also showed no lights to the front wheels, which usually there is at least one. After about 5 minutes, it all went back to normal.
    So is this indicative of having a bad speed sensor?
    Jul 2004
    1999/black/VX/black
    Mine has done this since 14k miles (when purchaced)
    it only does it when you turn max right or left...
    Quote Originally Posted by johnnyapollo View Post
    -- John
    TOD Speed Sensors
    Are these the same "Wheel Speed Sensors" noted in the shop manual?
  1. Does this look right?? One corner done on lift.
    By taylorRichie in forum VX Modifications...
    Last Post: 12/19/2012, 09:40 AM
  2. Torque Binding? No Codes..........
    By wwstone in forum VX Troubleshooting...
    Last Post: 05/18/2010, 12:49 AM
  3. Black Hood Insert Raising in One Corner
    By DeepSilentComplete in forum VX Talk...
    Last Post: 06/22/2007, 10:41 PM
  4. Hood corner lifting up?
    By Edward in forum VX Troubleshooting...
    Last Post: 03/18/2005, 04:09 PM
  5. Binding in corners
    By vx69 in forum VX Troubleshooting...
    Last Post: 09/22/2004, 11:06 PM
