edit
edit
I've the dreded ABS light...So I'm showing codes 42 and 43... which is FL Holding and FR Decompression valve short or disconnect...what should I check/replace?
???Control Module???
You know, no where else on the web do I think you find all of this information and experience. Un-real.
Kudos guys.
D.W.
DeeeMagnet,
Thanks for taking your time to put this together for us. This weekend I'm going to play around with this.
Peace.
Thanks Deer Mag...if there is a better example of why people should not think twice about a yearly donation to keep this site flush with operating capital, I can't imagine what it would be.
The potential to $ave hundred$, if not thou$and$ of dollar$ IMO, far outweigh$ a paltry donation of twenty buck$ a year.
Again, Thank You, for all the info. you provide, & for taking the time to gather & post it!
I don't know where you find all this stuff, but assume you would have to kill me if you told me...so I don't wanna know...
Yeah, I tried unplugging and plugging back in the ABS module...I'll try the cleaner...prob end up taking out the fuse, as ABS is over-rated...
This site is priceless...I know I've saved thousands using it. THANKS!!!
WTH.. the above tutorial is gone.. just says "edit"?
I bookmarked this a long time ago thinking I may need it one day. Well, one day is here and the instructions are gone? Anyone know where I can find it?
My TOD has thrown a checklight, any chance the procedure to check the codes is going to comeback soon?
Got'cher back.
Here's the file.
nothing on the ABS info?
Try Dis One
Thanks for the data Tom
I got a TOD code 13. From the circuit diagram I think I will need to remove the Front and rear Sensors and check the wiring closely. Anyone else fixed a code 13 before, have any other suggestions?
