Results 1 to 14 of 14
Thread: reset your clock
    reset your clock
    Don't forget to reset your clock this weekend.
    You should also replace the batteries in all of your smoke detectors too.
    Have a great weekend. I'm splittin early today because ... well, I CAN.
    TTFN
    There are places that still do this? I'm glad we have the same time year round!
    I can't wait for the extra hour! I can wash the VX after work again!
    Jan 2008
    Hey, Bart!
    I think we are losing an hour
    Speaking of the clock, I was able to set the clock in the VX to the correct time once I got the Dragon last week, per the instruction on page 5-20 of the owner's manual, but for the life of me, I can't get it to go into "time display priority mode" which is supposed to show the current time on the display, except when you change radio stations....
    Thanks for the heads up, tom4bren!
    Best,
    James
    Quote Originally Posted by snowtrooper1966 View Post
    Hey, Bart!
    Best,
    James
    Well, we are loosing an hour, but aren't we gaining an hour of daylight? Meaning, instead of getting dark at six, it will get dark at seven?
    Jan 2008
    You are correct, sir!
    Good for all except the vampires
    Thanked: 7
    Smile
    With the ignition in the ACC position, Press and hold down the button marked FM/AM (on the left of the radio under the volume knob). Now while holding that button down press the #1 preset button on the right of the radio. That's the hour button. Once the hour is set, press the #2 preset button the change the minutes.
    If you want to have the clock display while the radio or cd plays, press the FM/AM button then press and hold down the #4 preset button until it beeps (about 4-6 seconds). Normally the radio station or cd info shows all the time but now the clock will display after about 10 seconds.. To change back do the same procedure.
    Anita
    2000 Ebony #263
    AnitaProtich.com
    Aug 2006
    1999, Astral, Vehicross, 1619
    Quote Originally Posted by Anita View Post
    That is good info. I hate not having a clock right there and holding the button for a temporary time display.
    Spring forward / Fall back...I'm still cornfused.
    Jan 2008
    Thanks, Anita!
    I swear I did that as per the manual 10 times, and it never worked. I had to have the ignition to "on" to get the "time display priority mode" to take. It did not work for me with just "acc" on. When it did work, the display flashed the time to confirm mode selection.
    James
    Dang - after warning Y'all, I still forgot.
    Sometimes I worry about me!!!!
    Ah, being able to leave work without using headlights in traffic.... always a sign that spring is around the corner. Thank thee Lord!!
    2001 Proton VX #0690
    Wait, you work in video games, don't you? I didn't think they let you leave work at all! Or maybe that's just at EA...
    Quote Originally Posted by mdwyer View Post
    Ya, thats just EA, but we are fast approaching that milestone in this project as well. Comes about at the end of every project. High stress, no sleep, and malnutrition.... not even sure the job is worth all that....
  1. radio reset
    By MarylandJeff in forum VX Troubleshooting...
    Last Post: 03/11/2013, 10:14 PM
  2. reset the computer inspection
    Last Post: 02/11/2011, 03:26 PM
  3. TOD Disconnect - Ignition Reset
    By VR4-Quest in forum VX Modifications...
    Last Post: 04/20/2004, 07:03 PM
  4. CD Changer Reset???
    By Freon VX in forum VX Troubleshooting...
    Last Post: 09/05/2003, 05:42 PM
  5. Computer Reset....
    By gruven in forum VX Troubleshooting...
    Last Post: 06/19/2003, 10:15 AM
