Hi all, I was hoping there is a aussie driver of a 99 vx on this forum. My problem is this.
I am having troubles with the air con / heater. it only comes on at high setting on the switch. i have followed the advice on this forum for checking: fuse > relay > blower > resiter. (all appear to be working fine) i have yet to check the body earth to blower / resiter test. (as recommend in the manual)
I am thinking it may be a in dash switch problem but the manual i have down loaded from this site is for a left hand drive model. My model has a completly different dash set up then shown on the downloaded manual and is a right hand drive model.
Does anyone have a manual for the oz imported vx? can i buy a paper copy some where?
also is someone able to post a picture of their resiter that is hidden behind the glove box? i want to double check i am looking at the right part
please any help is going to be great, winter is coming and i need the bloody heater
edit
I went to our local holden dealer and asked to see if the reister would match that off a rodeo but it did not. my (and if i have the part correct) is a 3 pin. the one he showed me was a 6 pin (at least i think it was a 6 pin, been a long day)
perhaps i should have looked at a reister from a trooper?
