Results 1 to 15 of 15
Thread: ABS Light Came On?
    2001, IronMan White, #440
    ABS Light Came On?
    What do you think this could be. While driving a red stop light came on. I put on the brakes semi hard, but not enough to kick in the ABS system. When I started going again my ABS light turned on. It was solid. Also my ''CHECK" light came on. That light is just under the TOD wheel lights. Anyhow, the ''CHECK'' light would come on for about 5 seconds shut of for five and back on. While the "CHECK" came on my TOD would regester all lights on.
    I stopped again at a red light. Shut the engine off, restarted it. It came back on about 10 seconds later.
    I came home, cut the engine, restarted it, and drove it around. So far the light has not come back on.
    Any ideas?
    Thanks and Peace.
    Since both ABS & TOD warning lights were on, I would suspect a sensor or sensor connection. I'm making that guess on the assumption that both systems share info. from a common sensor.
    But like I said, just a guess.
    '99
    Ya can easily read the codes yourself in just a few minutes. Read 'em and write 'em down, then erase 'em and see if they show up again.
    http://www.vehicross.info/forums/showthread.php?t=12939
    Mark
    Thanks Mark! I'll give that a try.
    Peace.
    My ABS light goes on and off a lot. The check on the TOD does not however. Typically, in the morning, my ABS light will be off for a while and then it will come on and stay on most of the day...its annoying but so far I have had no ill effects....
    2001, Ebony Black, 1153
    ME too. Typically if I ever park on a curb or uneven surface it always makes the ABS light stay on. I have gotten so used to it coming on and going off I don't even worry with it. I am just going to take the bulb out when I get it back.
    '01 K. Silver #0383
    Hi,
    My ABS light has been coming on intermittedly for the last week. I took it in today to find out why and they are advising that the ABS modulator valve is fried. This is a $2900 part. They said that what this means is that I won't have anti-lock brakes but there are some very rare instances of complete brake failure (will happen suddenly, not gradually).
    Does this sound reasonable to y'all? And does anyone know if I can get (or if it's even advisable) a reburbished part for this that would be less $?
    thx j
    this happened to mine at the beginning of winter.. been driving without ABS with no problems, my brakes feel strong as ever, anita told me shes been without abs longer than that without any trouble, never heard of the sudden failure before
    I picked up an abs module with 50k miles on it for 100 bucks.. even if it doesnt work.. i still have 28 tries left before i equal the dealership price
    you could try flushing out the brake system completely and then next time you start the vx and the abs light is out, hurry to somewhere with gravel or dirt and do a few hard stops to engage the abs, could just have started to go because of not being used
    '01 K. Silver #0383
    I will definitely try your way! thanks for the input. j
    Where did you get the abs module? Mine seems to be out and I'm not paying $2900 for one!
    Dec 2004
    Tom, this sounds a lot like the problem I had over the winter - a wire harness clip broke on the underside, and the wires were hanging on the catalytic convertor. The insulation started to melt off and I got all sorts of sporadic ToD "check" and "ABS" warning lights, just like you are describing. After a couple of weeks of that, I finally shorted out the ToD fuse and all of the ToD lights went dark (don't recall what the ABS light did at that point).
    VehiGAZ, yeah.....exactly what happened to me. My wire harness melted too because of the catalytic convertor! Took my baby to get her checked out. I found out the ABS light code was coming up code 24. My Isuzu tech rewired it, and all lights came off.
    Well, my ABS light came back on after three months. Took it back to the tech, and he told me he would NOT charge me if the ABS light code was the same. Naturally, it was a different code. I had to pay the $94.00 to run the diagnostic test. It was code 44 this time. Basically, my tech told me not to fix it. He said even though my ABS light is on, I still have my ABS brakes. He also told me next time I saw him he would disconnect my ABS light if I got tired of looking at the it.
    Peace.
    picked it up from a parted VX .. think they are the same as in troopers and acura SLXs though
    Jun 2005
    01 Dragon Green VX 1286
    I remember when this site was new.. people complained about the terrible ABS system and complained why ISUXU wouldn't do a recall like they did on the
    RODEO. A few disconnected the ABS system..
    My system works real well though.. specially when you step on the brake and the gas at the same time... the gas overpowers the brake..
  1. Help with wiring light acces. to dome light
    Last Post: 11/24/2013, 09:49 PM
  2. Battery Light, ABS Light, No Power
    By TimG in forum VX Troubleshooting...
    Last Post: 03/22/2012, 09:23 PM
  3. Rear cargo light + underhood light
    Last Post: 05/29/2010, 09:00 AM
  4. spoiler tail light / hazard light question !
    By Spike in forum VX Talk...
    Last Post: 05/21/2007, 09:27 PM
  5. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 08:49 PM
