Results 1 to 4 of 4
Thread: Computer Reset....
    Feb 2003
    2001 Dragon 1051
    Question Computer Reset....
    At the risk of sounding stupid, I have to ask this silly question....
    How does one know if the computer has really reset? I am wondering because the first time I reset (after K&N) I was greeted by the wonderful horn honking.;oor; The past couple of times (latest after PVault) the horn has never gone off upon hooking the battery back up. Radio is reset, horn does work, and length of time unhooked does not change this.
    Sorry for the VX-101 question...
    -gruven
    "The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs. There's also a negative side."
    --Hunter S. Thompson
    Thanked: 7
    I wonder if it has something to do with the alarm.
    Anita
    2000 Ebony #263
    AnitaProtich.com
    Hmmm... not too sure. I can tell you this:
    I awoke one morning, about to run to the grocery, and found that I couldn't use the remote to unlock the doors. I unloked them with the key and heard a light, repetitive clicking inside. The overhead light wasn't on and the VX wouldn't start... just the clicking noise and the alarm light in the cabin was blinking with the clicking. I opened the hood and followed the clocking noise to the fuse box. I started pulling fuses and finally pulled the horn fuse... clicking stopped. I figured, somehow, the alarm had gone off lastnight and was on long enough to drain the battery or something. I jump the VX, then put the horn fuse back in, and everything has been normal since.
    I'm still not sure what cause it, but it was strange.
    2000,black,029
    Try setting a code by pulling one of the sensors connectors like the maf of tp and then put it back. The ses light should come on. Pull the battery cable and if the light goes off then the ecm is re-set. No other way that I know without using a scanner to see if the adaps have re-set.
    Andy from Isuzu America
  1. radio reset
    By MarylandJeff in forum VX Troubleshooting...
    Last Post: 03/11/2013, 10:14 PM
  2. reset the computer inspection
    Last Post: 02/11/2011, 03:26 PM
  3. reset your clock
    Last Post: 03/11/2008, 07:52 AM
  4. Code PO442 and readiness after the computer reset
    By Dean68 in forum VX Troubleshooting...
    Last Post: 02/05/2006, 09:26 AM
  5. CD Changer Reset???
    By Freon VX in forum VX Troubleshooting...
    Last Post: 09/05/2003, 05:42 PM
