Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: How do I replace the front brake rotors?
  1. #16
    Quote Originally Posted by VehiGAZ View Post
    ...so they might need to be shipped from Japan, so it could take a month just to get all the parts (Isuzu is no longer restocking their part inventory in the US, but will provide them from Japan as needed).
    What kind of slow airplane are they using? I flew from the North Carolina coast to Japan in 20 hours!
  2. #17
    Dec 2004
    No planes involved, I'm sure. Do you know how much a rotor weighs? It would double the cost to fly it here. I'm sure they ship parts on the slow boat (the one from Japan, though).
  3. #18
    1999,silver,vehicross,1891
    Front bearing repack when swapping rotors
    What are the benefits repacking bearings when swapping rotors; is it better to replace those also?
  4. #19
    Arrow two words...FRESH GREASE...
    Quote Originally Posted by CowboyErik View Post
    All lubricants break down with time/use.
    Examine the bearings upon disassembly/cleaning, if there is any sign of scorching (brown-almost black discoloration on the rollers), they should be replaced.(I found new @ Auto Zone)
    Some replace bearings every time they are due for repacking (every 30-40k), because they aren't THAT expensive, & since you already have it all apart anyway, why not.
    Any bearing that is replaced, should also have a new race, the part that the bearing contacts inside the hub, all new bearings come with a new race.
    Always replace the seals.
  5. #20
    '01 Proton #0317
    Pardon the dissenting opinion about replacing the wheel bearings from an "old school" wrench...
    Check your "country of origin" on those shiny new wheel bearings from Auto Zone or the like - my bet is they'll be from "a country not KNOWN for their wheel bearing technology" to put it nicely. Now check the country of origin on your OEM wheel bearings - Ahhhh...
    My own experience w/front wheel bearings is that as long as they've had reasonable access to proper lubrication for their life SO far, as long as the bearing seal has never been "violated", as long as they haven't seen contaminants/water intrusion, their useful life is ~200K miles with proper repacking (I personally recommend Mobil 1 synthetic grease). As previously mentioned, a proper examination is in order - evidence of rust, scoring, excessive heat, etc. is CLEARLY visible on the bearing and/or race surfaces. If they AIN'T bad, keep USIN' 'em!
    I've tested the "new" bearings from Auto Zone and the like with dial indicators - they're SH*TE! I can only imagine the metallurgy of those things - can you say "recycled steel"? Sure, I knew that you could...
    Just my .02, from an old geezer...
  6. #21
    Quote Originally Posted by TheGanzman View Post
    Good point on the quality issue, last time I did mine, I found one scorched & didn't have time to wait for a new one from Merlin, so I hitched a ride to the nearest parts store...
    Speaking of contaminant intrusion, I've found that "spirited" splashing through 3-4" deep puddles is enough to introduce water/mud into the hub.
    Can you say "red iron range mud"? ...
  7. #22
    Just checked & it's official...my memory is slipping...
    My replacement bearing was from NAPA, made in Chermany...oh well, I feel a little better about the quality anyway.
    Also, Mobil 1 synth...
  8. #23
    Jan 2008
    Also, don't forget to paint your calipers when your knee deep in this project already. Did mine with a two part brushable epoxy so there was no masking involved. Just remember to clean with a solvent and brake cleaner (naturally) and scrape off the rust first! Well worth the extra time:
    Also used the R1 Concepts rotors. Cheaper than the OEM,s IIRC.
    eBay link:
    http://cgi.ebay.com/ebaymotors/ISUZU...spagenameZWDVW
    And don't scrimp on the pads! I ran out of dough and used Raybestos, but think the extra dough and a little patience would have made a difference. OEM from Merlin! 'Nuff said!
    Best,
  1. New Brake Rotors and Pads
    By fotomaker in forum VX Talk...
    Last Post: 11/08/2017, 06:57 AM
  2. Changing Front Rotors and Tone Ring
    By mcaramb in forum VX Troubleshooting...
    Last Post: 07/16/2014, 06:03 PM
  3. Front rotors?
    By Tone in forum VX Talk...
    Last Post: 12/13/2004, 07:40 PM
  4. Help-Front Rotors
    By smcneal in forum VX Talk...
    Last Post: 02/13/2004, 02:49 PM
  5. New Brake Rotors
    By TDAWG in forum VX Modifications...
    Last Post: 02/11/2004, 11:11 PM
