Results 1 to 15 of 25
Thread: Had my front bearings repacked today
    Jun 2005
    01 Dragon Green VX 1286
    I took my VX to the local mechanic today that I use to do services a bit more involved then oil changes..
    He has a lift and a mechanic there who has a vested interest in the shop (its a quick lube place)
    He repacked my bearings for a small fee ( C-note ) and told me that the grease was drab and there were some burn marks on the bearings.. It was a good choice to have this service done..
    The VX was built in july of 2000 so the grease was almost 8 years old and suffered through many hot Arizona summers outside sitting parked and has 38,000 miles on it.. I will repack them again when I do my brakes at about 60,000 miles.. it was good peace of mind.
    Just wanted to pass that along for those of you thinking that the grease will make the brake change.. if your vehicle is a 2001 its almost 8 years old.. long time for lubricant
    Thanks for your time
    Jeff
    Mar 2005
    01 Ebony - #0379
    Yup. I agree.
    2001, IronMan White, #440
    I had a CV Boot replaced. When they do that do they automatically repack the bearing?
    Peace.
    Dec 2004
    Repacking the bearings is supposed to be done with the 30,000 mile "major" service.
    If you live in the heat belt and don't put a lot of miles on your VX, then having it done every 2-3 years is probably a good PM.
    Had my front bearings repacked today ...
    Me too...but I promised her I wasnt gonna brag abooot it!
    2000 IronMan #11
    How much did you all pay for the repack?
    Jun 2005
    I was quoted 3 hours book time from one mechanic down the street.. I used the other guy for various reasons.. and saved 35.00$ but 3 hours book time is a reasonable quote
    Oct 2006
    2000, Green, Vehicross, 0054
    Is this something reasonably easy that we can do ourselves? I'm sure it's messy but it's fun experimenting on the VX and trying things otu I've not done before. Do we need special tools?
    2000, Ebony, VX, 0370
    Thanked: 12
    Joe,
    I know that Kenny did his own bearing re-pack and he said that it wasn't tough just time consuming. I am about to tackle re-packing the front bearings and replacing the rotors and brake pads myself next weekend (to get ready for Moab), so I'll let you know how it goes. For now you can read up on the procedure in the article below from the planetisuzoo site.
    http://www.planetisuzoo.com/articles.htm/56
    Dec 2003
    Former Owner 0216
    Quote Originally Posted by Joe Isuzu View Post
    The hardest part is getting the bolts unstuck. Otherwise, for the drivway mechanic, it just a bit time consumming.
    '01 Ebony #0939
    I saw a bearing repacking tool similar to this (the other was metal) on one of those 4X4 shows on tv recently. It looked like it would fill the rollers evenly, and be a lot easier than doing it by hand.
    http://www.harborfreight.com/cpi/cta...emnumber=97489
    The roller bearing goes between the two plates. The main bolt is hollow (closed on the ends), and although you can't see it in the picture, also has a second hole in the bolt in the area between the two plates where the bearing will be. Once the bearing is placed on the bolt and centered between the two plates, a grease cerk is inserted into the other hole in the bolt, and a grease gun can then be attatched to send grease through the bolt and out through the bearing. Easy squeezy.
    '01 Ebony #0939
    As I looked at that picture, I'm pretty sure the one I saw on tv had the grease cerk on the end of the bolt so it wouldn't have to be removed in order to thread the clamping nut onto the threads, but otherwise it was the same principle.
    2000 IronMan #11
    Or this kind
    Found on ebay for under $20
    Oct 2006
    great, thanks guys, I'll look more into this after I get my tranny fluid changed, and after I get my muffler situation resolved.......................................... .................................................. .............................
    hmmm, looking at june by my accounts!
    Sep 2007
    1999 silver vx 0210
    Or this kind
    This is the part that made my bearing repack 100% faster and easy for a do-it-yourselfers. I would have replaced the bearings if they have any burning/scratching. Checker Autoparts has them for 200.00 +/- a few bucks thats the front only. If you have any questions shoot me a PM I just did this.
  1. Replies: 8
    Last Post: 12/18/2012, 09:01 PM
  2. Front Wheel Bearings
    Last Post: 06/02/2012, 05:51 PM
  3. Replies: 28
    Last Post: 09/11/2011, 03:29 AM
  4. Repack Front Wheel Bearings
    By DK in forum VX Troubleshooting...
    Last Post: 03/06/2008, 01:20 PM
  5. Cost of repacking front bearings?
    By Dare2Dream in forum VX Talk...
    Last Post: 10/28/2005, 03:55 PM
