Results 1 to 3 of 3
Thread: Rear Axle Pinion bearing & seal
    May 2003
    Question Rear Axle Pinion bearing & seal
    Anybody know what the Preload adjustment is when replacing the rear axle pinion bearing and seal along with (crush sleeve?). I did a search and only found things pertinent with the front axle along with rear axle seals but, nothing on the pinion bearing & seal. Mine is leaking pretty bad and I ordered the new parts today. I never could get the VX service manual on disc downloaded from Tone' site to work so I'd appreciate if someone knows the preload adjustment.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    181-217 ft/lbs. for nut
    3.04-5.64 in/lbs. for the flange preload for a new bearing
    I would get ahold of the manual for sure though, sounds like your going to need it.
    May 2003
    Wink
    Thanks!
  1. Outer rear axle seal tips?
    By Triathlete in forum General Tips...
    Last Post: 12/10/2012, 09:21 PM
  2. Replies: 2
    Last Post: 08/25/2012, 02:16 PM
  3. Pinion seal
    By Travelin2 in forum VX Troubleshooting...
    Last Post: 04/06/2009, 08:11 PM
  4. wheel bearing seal broken?
    By xiaoz in forum VX Troubleshooting...
    Last Post: 03/04/2008, 05:47 PM
  5. Rear axle seal
    By Project Big 1 in forum VX Troubleshooting...
    Last Post: 01/21/2006, 08:20 AM
